SOLD - 1991 Westfalia Camper Completely Restored 93k Original Miles, 2k Since Overhaul
rainbowdash
Asking Price: $35,000
Hi Everyone. If you are looking to acquire an absolutely immaculate and fully upgraded late model Westfalia, this is it. As you know, 1991 was the last year of the Type 3 Westy. I am the 2nd owner of this alpine white Westy which over a 3 year period has undergone a complete restoration/upgrade process. You will be challenged to find a nicer or more capable Westy. Off grid for a week and moderate off road travel is routine with her. Importantly, there are only ~93k originals miles on the van, with ~2000 miles on a newly overhauled and completely rebuilt Subaru 2.5L along with new suspension and wheels. The van has always been garaged, has no rust, completely repainted, and all appliances/features are functional. The upgrades are tasteful and not only increase usability but also safety. I am pricing this very reasonably as my family has too many other activities that we aren't using her as much as we should. Please feel free to ask any questions
Exterior:
  • Complete multi layer professional repaint 1 year ago in original Alpine White.
  • New front and rear Westfalia decals
  • Front Go Westy steel bumper with tow receptacle
  • Rear Go Westy steel bumper with tow recptacle
  • Front brushguard
  • Front skid plate
  • Two Go Westy Swing Away arms
  • Left Swing Away Ladder
  • Left Swing Away Carrying Tray
  • New Go Westy Utility hook up caps
  • City water delete with replacement solar plug
  • Right sided Fiamma crank awning
  • Left sided ARB awning
  • ARB deluxe awning room
  • Go Westy Hi-Jack mount for front bumper
  • Hi-Jack mount included
  • Go Westy Tow Shackle
  • Transparent window tint for purpose of heat reduction. Has 75% heat reduction capability
  • Clear bra on front, side mirrows, strike zones, and front door steps
Mechanical:
  • Newly overhauled Subaru 2.5L engine with custom engine mount - performed by Metric Motors, Centerville UT
  • Automatic fire suppression system in engine bay
  • Go Westy 16" alloy rims with BFG AT Tires. 2000 miles on tires. Full tread
  • Full size Go Westy 16" spare tire mounted on left swing arm ladder
  • Go Westy All Terrain Suspension bundle including:
  • Off Road Fox Shocks
  • Front and Rear Coil Springs
  • Ball joint spacer
  • Stainless Steel Cooling pipes
  • Go Westy Bigger Brake package front and rear
  • New braided stainless steel brake cables
  • 4 speed manual
  • Original clutch, 93k miles, no signs of slipping.
Electrical:
  • Go Westy third brake light kit
  • Healights replaced with LED
  • Go Westy exterior LED kit
  • Go Westy interior LED kit
  • Radio isolation switch
  • Professional house battery 12v system including breakers and fuse panel
  • 200 AH AGM battery under bench
  • Iota smart charger
  • 100w Renogy solar suitcase with cord extension. Can park van in shade while solar panel is in sun
  • MPPT solar charge controller
  • Off road LED flood lights installed in brush guard with dash switch
  • House battery can charge 3 ways: Solar, alternator, and shore power
  • 3 tastefully located 12v receptacles for passenger device charging and various USB use for upper and lower bunk
  • Blue Seas Isolator/Combiner
  • Flush mount CO/Explosive gas detector
Interior:
  • 3 point rear seatbelts
  • German VW rear headrest installation
  • Full Go Westy interior mats: Front, pass through, kitchen, and rear
  • New Halon fire extinguisher
  • Front and Rear seat covers (original upholstery is pristine)
  • Original Germany VW child's cot installation for front sleeper (yes van now sleeps 5)
  • All original cabinetry which is pristine
  • Last slot on headrest posts filed smooth for easy removal.
Kitchen/Camper
  • New TF49 fridge with color matched laminate
  • Propex heater installed under fridge with color matched laminate
  • Propex thermostat mounted above bottom bed
  • Upgraded and larger Go Westy propane tank with skid plate
  • Go Westy upper bunk ladder
  • Francher's insulated and waterproof pop-top tent wrap. Stores behind upper bunk when not in use. Seconds to install, and keeps top warm and waterproof.
  • Go westy shower tent. Attaches to rear hatch.
Asking $35,000
Known Problems:
  • Side mirrors need motors replaced. Can be adjusted manually
  • Small cosmetic crack in plastic trim around steering column
  • Small cosmetic burn mark (dime size) in trim above kitchen
  • A/C works well for a Westy, but still leaks refrigerant. Needs to be periodically (every 3-6 months) recharged
522817
522818
522819
522820
522821
522822
522823
522824
522825
522826
KillerB
Electrical question: One of your bullet points says, "200 AH AGM battery under bench". But one of the pictures shows a LifeBlue LiFePO4...no mere AGM battery.
Which is true...is that LifeBlue in there or did you swap it for a regular AGM?
KillerB
Interesting, a very nice looking rig. I park in a garage apparently designed for hobbits, very low clearance at the door. May I ask you to measure exactly how tall you van is at its tallest spot?
I suspect it is about 2" too tall for my space...but worth checking.
xander69
