Diesel 80
Rare Left Hand drive 1HD-FT Toyota diesel 4.2L 24 valve with 12k miles! Dual tanks holds 67 gallons of fuel on board. With a range of over 1,300 miles between fill ups. With the Safari kit, this engine puts out approx 218HP & 347 Ft lbs. This kit is unbelievably expensive and near impossible to get. This is an instant runner with fresh fuel and batteries. There's a lot to look at. I have multiple extra OEM Toyota water pumps, fuel filters, timing bets, oil filters, air filters... I'm sure there's other parts. There's a ton of JDM parts and goodies for this as well. Interior is removed and the roll bar is tacked in, so it can easily be removed. No headliner, carpet nor sunroof. Those are easy and cheap to find. Have all, if not almost all interior parts including leather door panels (in addition to the 92 clothes) and leather 2nd & 3rd row seats (think I have multiples). You can finish this off easily back to stock or leave the cage and go wild... or you can swap cabs and be done. The LC has a 13.5k BTU AC unit where the sunroof was. Intentions were to run a triple battery set up with a DC 280 amp Alternator pushing through a 8-12k watt inverter. This is registered as a DIESEL and there's NO CALIFORNIA SMOG!! Health changed my priorities and it's best to simplify and sell all my projects and toys. Location is Hemet, Ca. I can also be reached at axxisoffroad@gmail.com. Thank you for looking, Brian.
1992 HDJ80 Diesel Land Cruiser- Japanese version of the Toyota 80 Series Landcruiser
-1HD-FT Toyota Diesel 4.2L 24 valve
-Polished valve cover
-Safari inter-cooler
-Safari Polished inter-cooler intake
-ARB Snorkel
-A442F Toyota transmission w/ lock up TC
-Dual trans coolers
-Center Differential Lock
-1995 FJ80 High Pinion front Axle w/electric locker~rebuilt end to end
-1995 FJ80 rear Axle w/electric locker~rebuilt end to end
-Diff covers
-Toyota big brake disk upgrade front & rear
-New OME 3" springs
-New Rancho RS9000 shocks w/ in cab controls
-New Auto lift coil air bags w/ in cab controls
-Slee rear upper & lower control arms
-Slee Panhard Rod
-5 Linked
-ARB Front Bull Bar
-Warn Winch 9000XI
-KAYMAR Rear Bumper with swing away spare and Jerry can **Extremely expensive IF you can find one**
-Slee Aux 42 gallon fuel tank Kevlar coated
-Slee Dual Filler Neck
-Walbro frb-5
-Water Separator/Fuel filter Racor 500
EXTERIOR~
-Frame painted
-Sliders
-Imported Toyota Turbo LC grill
-13.5k BTU Low profile RV A/C-Heater installed in sunroof enclosure, but hidden in roof rack if one is installed
INTERIOR~
-Is removed, but complete
-Recaro Front seats heated
-Dual dash mount with Pyro and boost gauges
-Toyota factory JDM turbo instrument cluster
-AOR Roll Cage
ELECTRONICS INTERIOR~
-Alpine CVA-1006~Have
-Alpine Navigation~Have
-Alpine 6 Disc hanger~Have
-PPI EQ
-1/2 DIN DVD player
-Aimes 8,000-12,000 Watt Power Inverter
Safari Intercooler System
Safari 4x4 Snorkel System - Lexus LX470 / Land Cruiser 100 Series.
www.safarisnorkel.com
-ARB Snorkel
-Dual trans coolers
-Diff covers
-New OME 3" springs
-Slee Panhard Rod
-5 Linked
-ARB Front Bull Bar
-Warn Winch 9000XI
-Walbro frb-5
EXTERIOR~
-Frame painted
-Sliders
INTERIOR~
-AOR Roll Cage
-PPI EQ
-1/2 DIN DVD player
