SOLD-1993 Ford Bronco XLT 5.8L Prevolander
Madmaxwell87
I'm selling my bronco as it does not fit in with the type of wheeling we do, and I would rather see it get used then sit in the garage. This truck made it from CA to NM and up to Denver and back. There’s no rust anywhere-CA truck for 98% of its life. Passed CA smog when I bought it and NM smog in late 2022.
XLT, 5.8L. 216,918 miles
Located in ABQ,NM-Clean NM title in hand
$10,500
Modifications
  • F and R axles rebuilt (Moog ball joints, all bearings) and regeared to 4.56, limited slip in both axles (Eaton Truetrac), converted to manual Warn hubs by AVS (drain added to front axle)
  • Solo Prerunner Front bumper- professionally painted.
  • ProtoFab RockSolid Double Rack rear bumper with jerry can and spare tire-reinforcement bracket fabricated and installed by AVS (led license plate bolts)
  • Rocky Mountain Broncos rock sliders
  • (5x) 33x12.5x15 Mickey Thompson Baja Legend EXP installed at 216,818
  • (5x)15x8 Vision Manx wheels
  • Desolate F350/Ambulance steering, Redhead steering box and pitman arm
  • Desolate Stage 1 2” leveling kit with dual Bilstein 5100s
  • Desolate center console with Tuffy center console (Element E50 fire extinguisher and mount on rear)
  • ProEagle Kraktos 3-ton big wheel jack and mount
  • Desolate Transfer case skid plate
  • Desolate Dana 44 TTB Bash Guard
  • Desolate Fuel Pump Access Panel
  • Desolate Dash Brace
  • RuffStuff rear differential cover with lube locker gasket
  • Rear add a leaf and Bilstein 4600s
  • PRP Daily Driver +2” width seats on Solo seat mounts
  • Rugged Radio 50w GMRS radio, external speaker and magnetic antennae mount on roof.
  • Garmin Overlander and charging mount with hard mounted reverse camera.
  • 3M 15% tint professionally installed by Tint & Trim Factory on all windows in July of 2022
  • LED reverse lights in aftermarket housings, LED 3rd brake light and tailgate light strip
  • Magnaflow muffler
  • Pioneer DEH-24220BT stereo with Kenwood KFC-1696PS in front doors and Pioneer TS-A682F in the rear panels
  • Artec Industries racing quart crate with coolant, power steering fluid, and trans fluid
  • Bed area sprayed with truck bed liner
Maintenance
  • Motorcraft spark plugs, wires, distributor cap, rotor and coil
  • Koyorad radiator, cap, upper and lower hoses and reservoir
  • Fuel Filter, Injectors, IAC valve, EGR valve, position sensor and solenoid/motor, Front passenger O2 sensor
  • Battery replaced 6/20. All cables upgraded with kit from Custombatterycables.com
  • Front brake calipers, pads and extended brake lines
  • Rear brake drums, shoes, wheel cylinders and hardware
  • Serpentine belt, belt tensioner and idler pulley
  • Moog Radius arm and axle pivot bushings
  • Moog Rear sway bar end links and bushings
  • Window motors (tailgate window too)
  • Motorcraft power steering pump and pulley
  • Bosch alternator
  • LED dash and map lights
  • Husky floor liners
  • Oil catch can
  • New smoked headlights and Sylvania SilverStar Ultra bulbs
  • Fuel filler tube
  • Front and rear window weatherstrip/ window scrapers replaced inside and out.
  • Transmission fully rebuilt with new torque converter and transfercase resealed (pan with drain plug added) by Tranco in November of 2022
  • Rear driveshaft rebuilt while transmission was getting rebuilt.
Comes With
  • Solo 30” single row led bracket kit
  • Solo Motor Mounts
  • Threat Extended Rear Upper Shock Mount kit with hardware
  • Delphi fuel pump
  • Lots of stock parts and Chilton repair manual
Work Done by Previous Owner/s
  • Oil Pan seal ~209k
  • Water Pump, Timing Chain Cover, thermostat ~205k
Issues
  • AC not working- compressor won’t turn on. It was professionally topped off in early 2022 and it held vacuum fine. It’s been ice cold up until the last time I took it out. The compressor won’t turn on. It seems like it’s the low-pressure switch.
  • Rear window dash switch does not work. It used to but has stopped. Window works fine with the key in the tailgate. Dash switch and window motor are new.
  • Paint faded on hood.
  • Dents in rear quarter panels
gp01
