(SOLD) 1994 Toyota Hiace KZH106 4x4 Van
blzke
1994 Toyota Hiace 4x4 Van - Diesel RHD
Asking Price: $19,995
Full Time 4WD - Super Custom Limited Trim
Hiace H100
1KZ-TE In-line 4 Turbo Diesel Electronic Fuel Injected Engine
4-speed Automatic Transmission
129hp 3.0L
Rust free
Model Code: KZH106W-MFPQT
Mileage: 132,XXX
Engine: 1KZ-TE 2982cc 4 Cylinder
Fuel Type: Diesel
Transmission: 4-speed Automatic w/ OD
Drive: 4WD
Steering: Right Hand Drive
Exterior Color: White/Gold
Interior Color: Brown
4x4 Right Hand Drive Toyota Van, great camper setup.
I imported this van from Vancouver, BC in April of 2019. It is in excellent condition and I have all of the service records since it has been imported from Japan. This full-time 4wd van does well in the snow and is reliable beyond its years. At only 132,000 miles, this 1KZ-TE diesel-powered van is just getting started. The rear seats were taken out to make room for a full-size bed in the back. I do still have both sets of rear seats, all of the seat belts and tracks/trim for the seats if you want to re-install them and take them home with you. Plenty of upgrades and necessary repairs have been made to this van to ensure that it starts up every time and runs efficiently. The exhaust gas recirculation system has been blocked in order to keep the engine clean and running for longer than its factory expectations.
These vans rule and more and more are popping up in the states. There are good resources for maintenance online via forums and Facebook, and lots of places to order spare/replacement parts and supplies for future repairs. This van has been extremely well maintained and has had some of the bigger repair jobs done in the past few years (rear main seal and flywheel replacement).. whereas you see a lot of these vans for sale, these repairs have not been done on most floating around the market currently.
Oil and oil filter changed every 3,000 miles. I have used Stanadyne diesel fuel additive in every tank of diesel I have put through this car.
Features:
Power seats for easy adjustment
Hot-pot hot water heater (yes, it works!)
Fridge/sandwich warmer/ice maker in center console (yes this works too! Runs off of A/C)
A/C and heat, new A/C belt installed in August, blows cold
Digital Dash, km and tach
Power windows, front
Rear heat and A/C
Three sunroofs, front, middle and rear.
Pioneer Stereo w/bluetooth, AUX plugins
Original floor mats w/rubberized floor mats for winter months
Full-size bed frame w/5” memory foam mattress (53”x75”) bolted to frame, easy to install/uninstall
Power curtains (taken down and set up with custom curtains) still have all original curtains and hooks
In-line heater installed for cold winter startups
Upgrades and recent repairs
2” Roamer NW lift kit
Dobinsons front & rear suspension
Bridgestone Blizzak WS90 (500mi)
2” hitch
EGR Delete done
In-line heater for winter starts
Powder coated wheels
New curtains custom made (orange)
Thule Roof rack crossbars
Repairs:
Rear Hatch Struts replaced (6/16)
New Suspension, shocks and coils (11/19)
Front sway bar bushings, stabilizer links and brackets replaced (6/17)
Rear Main Seal replaced (6/17)
Flywheel Ring Gear replaced (6/17)
Turbo Return line pipe replaced (6/17)
Windshield wiper motor replaced (5/14)
Inline heater installed (9/17)
New glow plugs (4/19)
New air filter (4/19)
Starter solenoid replaced (5/19)
New battery (4/19)
Timing belt replaced (140,000km)
Blemishes/issues (seen in photos)
Very small rust spot near sliding door (was quoted $125 to repair). Paint chipped on sliding door. Small dent on passenger side door. A few small scrapes (since filled with paint) on driver side door. The telescoping steering wheel does not tilt (broken motor) but it lifts up and down still. It is in a good position and I have not had any issues with its placement.
all questions can be directed to 509.435.5010 if you want to discuss further or are seriously interested.
more detailed photos can be seen here: https://fdm.media/#/94hiace/
DanoWall
