**SOLD**1995 Ford 4x4 E-350 7.3L Turbo Diesel Quigley
delvin
***SOLD****
Hello everyone! I am looking to sell my Quigley van and thought someone here might be interested. I have put a lot of time and money into this van over the last year with hopes of travelling cross-country with it. Unfortunately, we have some home remodeling planned and we are considering using the van to help offset the costs. If there are any questions or if certain pictures are needed let me know!
The van is fully undercoated and in great shape for its age. The van body was originally used as canoe delivery van in Northern Michigan (only during summer). I have the VIN build sheet for the vehicle from Quigley for the chassis/powertrain.
Craigslist Ad with more photos:
https://detroit.craigslist.org/wyn/cto/d/1995-ford-4xl-turbo-diesel/6411713182.html
Price: $17,375 OBO
Mileage: 145k
Note: This van had a body swap done. Both titles for the body and chassis/powertrain are clean green Michigan Titles and in my name.
Powertrain/Drivetrain Info:
  • New High Pressure Oil Pump (Previous owner)
  • New Injection Pressure Regulator (Previous owner)
  • Turbo rebuilt and Wicked Wheel 2 installed
  • Fuel bowl rebuilt with new o-rings
  • Dana 60 front
  • Dana 60 rear with Trac Lok limited slip
  • New fuel pump
  • New fuel tank and straps
  • New fuel filter and air filters
  • New 4" Diamond Eye straight exhaust w/ Muffler Delete
  • Up-pipe gasket and turbo seal
  • New glow plug relay and starter relay
Chassis/Tires/Brakes Info:
  • 35" Toyo Open Country A/T II Extreme II tires (285/75R18) 95% tread
  • New front brake lines, hoses, calipers and pads
  • New monotube shocks all around
  • New front springs (to return to stock ride performance)
  • New track bar bushings
  • New sway bar bushings
Body/Interior Info:
  • New blacked out headlights and corner lights
  • New grille from 2003+ Van
  • New Motorcraft batteries
  • New padding under the vinyl flooring
  • Insulation added behind headliner and side panels
  • JVC Radio with Bluetooth Audio
Known issues:
  • Front tires rub slightest bit on inner fender when turning
  • Crack in the windshield
  • Cruise control does not work
  • Parking Brake does not work
  • No A/C components; I have the front A/C lines
  • Rear HVAC needs A/C and coolant lines run to it
  • Oil Leak from Turbo pedestal and rear diff
xander69
