SOLD - 1999 k2500 4x4 Chevy Suburban - AZ fleet truck, low miles - Madison, WI
kweetech
https://madison.craigslist.org/cto/d/madison-1999-chevy-suburban-3-4t-4x4/6806884715.html
496691
496692
496693
496694
496695
496696
496697
Super clean 1999 k2500 Chevy Suburban ¾ ton 4x4, 9 passenger. 136k, vortec 350, 4l80e auto, g10 rear locker, 4:10 gears, skid plates, floor shift 4x4. Very clean interior with vinyl floors, crank windows, cloth bench seats (have third seat stored inside). Rust free AZ truck came to WI in 2010. Was a fleet vehicle in AZ used to haul soccer team. Never really used for towing. I am the 4th owner. Brand new 265/75-16 E rated General Grabber AT's on refurbed 16x7 ford e250 steelies (stock chevy are 16x6.5). Have stock wheels and tires (decent Michelin LTX's)
Current issues...abs light is on because of wheel sensor. Doesn't bother me, haven't fixed, brakes work great. Turn signal switch intermittently clicks like it's on when it's not. Everything on stalk functions correctly, will include new switch. Have all AC Delco stuff for fresh tuneup, haven't had time to put in. Typical paint flake of older GM truck, not too bad.
Truck is a beast in the snow and cold, starts all winter, daily driver.
Here's a partial list of stuff done (that I had records for) ->
6/2/10 - Hitch installed
3/15/2010 - Serp Belt/diff and gear lube/air filter/oilchange/fuel filter - 58k
3/16/2010 - alignment - 59k
3/26/2010 - cap/rotor/wires/plugs
3/29/2011 - headlights/oil change
6/21/2011 - front pads - 70k
04/02/2012 - front rotors/repack bearings 76k
10/22/2012 - front hub assembly, br930406 / 4 door lock actuators
3/13/2016 - intake gasket/bolts - fel pro 230 MS98000T
8/23/2016 - Trecek Chevy - idler arm/pitman arm/ L and R upper and lower ball joints/left inner tie rod end/repair seized rf caliper/cap and rotor/rear broken wheel stud/rear u-joint/wheel balance and front alignment - 109,000
1/17/2017 - cap/rotor
9/2/2017 - fuel pump assembly/fuel filter/fuel tank lock ring/fuel pump relay - 118,000
2/15/2018 - oil change - syn blend 5/30 - 123833
7/31/2018 - reman brake caliper/reman half shaft RF
8/01/2018 - brake shoe/whl cyl/bearing pack/wheel bolt
9/6/2018 - reman brake caliper (LF?)
12/2018 - rear leaf spring bushings, alignment, back windows tinted, full detail, oil change, repaired exhaust hangers, full dealer inspection, new oil cooler lines.
$7200 with new wheels/tires, $6500 with stock wheels/tires.
More pics in CL ad.
Great truck, but ¾ ton is a little much for my needs, and still really want a squarebody or another 4runner. May consider trades.
shellb
It’s going to be and I’ll be putting in another order!
Maybe I’ll need to stop by and save shipping!
shellb
Hi all - I’m going to be selling this soon.
If anyone is looking and would like to make a deal for a really good price please PM me. Like $4K cheap.
Literally bought this and hardly put any miles on it other than driving it back to CO. Also did couple of grand in repairs.
It is just sitting here and not being used, really deserves to be at a new home.
Very flexible on price, especially if I don’t have to do full for sale ad or deal with clist buyers!
