underkill
SOLD SOLD SOLD
2005 Dodge Ram 3500 SRW
4x4, crew cab short bed, automatic
5.9 Cummins diesel 24v ~183k miles
3" lift and 37" tires
We bought this truck about a year ago with plans to put a camper in it and go overlanding part time. Life changed and now we're moving onto a boat instead and don't need a vehicle at all. We drove the truck across the country 3 times and put a lot of highway miles on it. The truck runs and drives flawlessly, has never had a tuner or chip in it, and has all the paperwork on the mods and maintenance since new. She's set up for a Four Wheel Camper by Main Line Overland. It's had all the maintenance and mods to be a reliable and solid truck.
Drivetrain:
Reliable pre-emissions Cummins. We always run fuel additive in it, as did the previous owner.
*Brand new* injectors and lines (stock size)
Rear axle has a Mag-hytek diff cover
Front driveshaft rebuilt last year.
AFE Cold air intake with particle bag cover. I have a 2nd backup filter I will also include.
5” Magnaflow Turbo back exhaust with 5” Magnaflow high flow Cat.
150 GPM FASS Fuel filter kit, installed by ATS. The additional filters save the injectors from damage.
Upgrade pressure solenoid and transducer in transmission. Deep ATS Tranny Pan.
Fuel mileage has been around 15mpg mixed
Suspension/steering:
3" lift, Thuren 2.5 custom King Shocks front rear, 2.75 tune, Thuren front springs Thuren control arms, Thuren Rear long travel leaf springs and shackles
BD Track bar, sway bar end-links, and steering box brace
Synergy Steering tie rod kit with fox steering dampener
Dynatrac rebuildable ball joints
Air Lift Ultimate 5000 air bags for load and camper leveling
Steering system replaced ~3 years ago. 8.3 Mopar steering box, hydro boost, and steering pump.
Wheels/Tires:
Black Pro Comp rims 17x9
37" Toyo Open County AT3, ~15k miles
Fullsize spare tire on matching rim
Rigd Ultraswing Mega-fit tire carrier
Body:
Custom steel bumpers. Very low profile and sleek.
Line-x bed liner, bed rails, fender, rocker panels, and grill
Includes mesh and winter grill covers
ARE canopy with rearview camera, brake light, and locking solid side doors.
Will include tailgate
Red tow hooks
Trailer hitch
Electrical:
New battery cables and grounds
Interstate batteries
Wiring run to bed with plug to support camper. (we had a FWC on it for a bit. so it's set up for one of those!)
Wiring run to inverter mounted underneath driver seat with remote on/off switch.
Will include gauge panel and a few gauges that were never installed
Towing package with brake controller
Interior:
Infinity Audio, custom Pioneer 4200NVX head unit, rear view camera, microphone, delayed ground bypass, Apple Car play, Android, aux and usb.
Heated leather seats with suede inserts. (front in good shape, rear has one small puncture in it)
Weathertech front floor mats
Sound dampening has been installed in the entire cab minus the roof and doors. I will include what I have left so you can finish it if you want. Made a big difference in interior noise.
Things it needs:
Nothing.
The transmission is hard to shift out of park. There's a spring that gets replaced to fix it. I will include the spring.
It has the rock chips and little scratches you would expect on a rig with 180k. No real damage or large dings though.
It's time to paint the frame and undercarriage. No rot or damage at all, but there's some surface rust starting to form.
We have two keys, but one fob. I have a second fob that needs to be programmed still.
Occasionally the wipers will do weird things. I have the switch that needs to be replaced, but haven't gotten to it yet.
The headlights are cloudy and old and could be replaced.
Located in Melbourne, Florida. Willing to travel within reason.
Asking $25,000
Title in hand ready to go!
SOLD
Drivetrain:
Wheels/Tires:
Body:
Red tow hooks
Trailer hitch
Electrical:
Interior:
Things it needs:
Nothing.
Asking $25,000
SOLD
