SOLD: 2005 Sportsmobile 4x4
pjpvi
2005 Sportsmobile 4x4 EB50
  • Second owner. Purchased from original owner in 2006.
  • 134,634 miles (as of writing this)
  • Ford E350 Extended van.
    • 4x4 conversion and camping conversion performed by Sportsmobile (now Field Van) in Fresno, CA.
    • Electric pop-top
    • Seats 5 / sleeps 4
Price: $67,000
Email: PacificAdventuresVan@gmail.com
Drivetrain:
  • 6.0 PSD
    • Amsoil synthetic oil since new
    • Dual remote oil filters
    • Bullet Proof Diesel - FICM and EGR cooler
    • 8 new fuel injectors in 2019
    • Upgraded DC Power - 180amp alternator
    • Upgraded 6.4PSD starter
    • Ceramic coated up & down pipes. Down pipe wrapped.
    • Otherwise stock with mild tunes
    • Vents in hood to aid in heat dissipation
    • Runs strong. Always passes CA smog.
    • Opti-Lube - Summer Lube + Cetane Diesel Fuel Additive with nearly every tank of fuel
    • Transferflow 46 gallon fuel tank
  • Atlas transfer case
    • RWD hi / RWD lo / FWD lo / 4WD hi / 4WD lo / Neutral
  • Dana 70 full float rear axle with Trac-Lok LSD
  • Dynatrac ProRock 60 front axle with TrueTrac differential
    • Yukon locking hubs
    • Dynatrac rebuildable ball joints
Suspension & Tires:
  • Deaver progressive springs
  • Bilstein remote reservoir shocks
  • Progressive bump stops
  • Twin Bilstein steering stabilizers
  • Nitto Ridge Grappler tires 315/75R16 (35")
    • 4 with ~3,000 miles
    • Spare ~20,000 miles
Bumpers:
  • Front Bumper
    • Aluminess
    • 12,000 lb Warn winch (steel cable)
    • Lockable access to winch
    • PIAA lights
  • Rear Bumper
    • Aluminess
    • Lockable storage
    • Passenger side Aluminess swing arm with Aluminess locking box and Buyers locking box
    • Driver side custom steel swing arm with spare tire and receiver for a 1upUSA bike rack (bike rack not included in sale unless negotiated separately)
    • Propane quick disconnect on passenger side of rear bumper. This has been used for a bbq. Feeds from main chassis mounted propane tank.
    • Second set of brake / signal LED lights
    • Back-up lights
Systems:
  • Propane:
    • Propane tank is frame mounted on driver side. Feeds furnace and quick connect on rear bumper for bbq. Plumbed for Suburban water heater that was removed (but available if the buyer wants it).
    • No built in stove.
  • House electrical:
    • Shore power input on driver side. Cable provided.
    • Qty 2 Lifeline AGM GPL-4DL batteries chassis mounted near rear axle
    • Inverter (2500 kw?)
    • Solar
    • Microwave
    • Norcold Refrigerator
  • Water:
    • Pressurized water fill on driver side to ~18 gallon tank under couch.
    • Gravity water fill on passenger side to ~10 gallon tank where water heater used to be.
    • 18 gallon tank can be filled internally using built in pump from 10 gallon tank in situations where pressurized fill is not available (common in Baja).
    • Separate drinking water faucet that is filtered with UV light. Always tastes great regardless of water source.
    • Outside shower accessed just inside rear doors.
  • Heater:
    • Suburban propane furnace
  • On-board Air:
    • Outlet on driver side.
    • Air tank is frame mounted on passenger side.
    • ARB twin compressor in compartment under bed.
  • Stereo:
    • Kenwood head unit
    • ADS - amp, subwoofer, rear speakers
    • Polk Audio front speakers
Other Interior:
  • Seats
    • Sheel-Mann (heated)
  • Communications
    • Kenwood TM281 144MHz FM Transceiver (HAM radio)
    • Original CB radio and antenna available if the buyer wants it.
  • Custom cabinet / shelf above counter
  • Under van storage accessed from inside rear of the van.
General Condition:
  • General condition is good!
  • Paint:
    • Some paint pealing off on driver's side. This is the side that predominantly faced the sun for a great deal of my ownership when it was parked in my driveway. Has been parked inside the last several years.
    • Pinstriping from brush
    • Otherwise, good for it's age.
  • Bumpers & ladder:
    • Some scrapes and dings.
    • Powder coat finish is fading.
  • Mechanical:
    • Generally good. No issues to address.
  • Interior:
  • Body damage:
    • Pinch weld area behind passenger side rear tire from coming down on a boulder while 4 wheeling.
    • Minor damage to rear doors from backing into a tree that pushed my swing arm bike mount system into the doors.
    • Rest of body is straight. The van has never been in an accident.
  • Pop-top
    • Good.
    • Recently refinished with bed-liner material.
    • New perimeter rubber seal from SMB (Field Van)
    • 3 additional layers of fiberglass added several years ago. This substantially increased the strength of the top over original.
    • Power electric lift system works well.
    • Canvas has some wear marks but generally in good condition.
    • Vinyl windows, screens, & zippers in good condition.
    • Yakima load bar system (3-bars included with key locks)
Additional Photos:
PXL_20230526_204643214.jpgPXL_20230526_204717871.jpgPXL_20230526_204725040.jpgPXL_20230526_204731437.jpgPXL_20230526_204755002.jpgPXL_20230526_204921121.jpgPXL_20230526_210230809.jpgPXL_20230526_210123692.jpgPXL_20230526_205808686.jpgPXL_20230526_205622433.jpg
iStan814
