SOLD 2006 Dodge Ram Power Wagon
zeketpf
2006 Dodge Ram Power Wagon, Crew Cab
Original owner. 198,3xx miles on it and is in good shape for the year (normal scuffs and light scratches typical of a 18-year-old truck). No rust and paint is in good shape; no peeling or clearcoat issues. Mechanically in good shape.
$12,900. Make an offer. Great foundation to build on. Located in Lynchburg, TN.
Original features:
Built on the 2500 series frame.
4.56 ring and pinion gearing front and rear.
Electronic front and rear lockers w/ in-cab controls.
2" factory lift.
Electronic in-cab sway bar (AAM Smart Bar) disconnect for 32" of articulation.
Undercarriage skid plates for steering damper, transfer case and fuel tank.
12,000 pound Warn winch.
Special fuel mapping for softened throttle response in 4-Low for better control/crawling.
160 amp alternator and 750 amp battery.
34 gallon fuel tank.
max payload 2,250 pounds.
max towing 10,600 pounds.
NV271 transfer case.
5-45RFE auto trans.
4.56 gears
5.7 Hemi
Sunroof and power sliding rear window
Added:
Brand new 750 CCA battery.
Upgraded T-style steering linkage
DT Pro Fab steering box brace
Line-X over the rails bedliner
Roll Bak aluminum tonneau cover
K&N/Airaid cold air filter system
Off road light mounted behind the grill
Locker bypass
Tinted windows
Ravelco Anti Theft Device
Cooper Discoverer ATP tires
Small issues:
Small dent on rear bumper
Dent/scratch over rear fender
Original PW floor mats, although driver mat has a hole
Typical service 4WD indicator light, was told it was due to a rear differential sensor
One hub cap scratched up
Maintenance:
Regular oil changes with Synthetic oil
New steering dampener 2022, 193588
New track bar bushings 2022, 193101
Changed front rotors, brake pads, calipers, & brake lines 2021, 170167
New wheel hubs/bearings 2020, 163988
XRF Lifetime upper & lower ball joints 2020, 163988
New Bilstein 5100 shocks, all four
Wired for locking tailgate but needs new actuator
New pinion seal 2017, 136269
New water pump 2017, 136590
Changed spark plugs at 2011, 62000
https://www.autotrader.com/marketplace/buy/dodge/ram-2500/2006/3D7KS28D86G245158
20231115_110619.jpg20231115_110721.jpg20231115_110736.jpg20231115_111241.jpg20231115_115104.jpg20231115_115113.jpg20231115_115128.jpg20231115_115144.jpg20231115_115153.jpg20231115_110804.jpg
08powerwagon
Love my '08. I've owned it since new and it has never let me down. Sounds like you have kept her in great condition. The perfect overlanding platform with more payload capacity than a new one. The locker bypass is a must have. Great color too. :) GLWS!
gp01
