SOLD - 2006 E-350 EB 4x4 Quigley Diesel - Denver Colorado
landshark99
Asking $38,000 or best offer
Mileage: 162,423
Overview:
I am selling my 2006 Ford E-350 diesel 4-wheel drive (4x4) extended body Ford Van that currently has 162,423 miles; however, I do drive it from time to time so miles may vary. I am the third owner and have put about 30K miles on it, previous owner (Montana) about 30K miles as well. The first owner (California) installed an upgraded EGR "bullet proof" oil cooler and ARP head studs with new gaskets at a professional diesel shop in California around 2012 (I have a copy of this invoice/documentation). The 4x4 conversion was done by Quigley 4x4 in 2006 and I have the parts list and other documentation from that conversion as well. The interior conversion was original completed by El Kapitan in 2006. (I have a copy of the El Kapitan invoice for verification).
The van runs and drives great and has been a reliable, super solid, fun, all season rig taking me into the Colorado mountains in the dead of winter, throughout the desert south west in the middle of summer and even remote locations up and down Baja Mexico including a trip to Cabo San Lucas. When I purchased it, I removed the 12 seats from the rear and installed two new reclining Honda Odyssey seats on swiveling bases behind the front captain’s chairs and built a queen bed size wood platform in the very back to optimize storage space underneath (two feet of vertical space under for stackable bins) but still have a place to sleep and store clothes etc. The platform can easily be removed. Last year I had the front two captain’s chairs re-upholstered to match the rear seats and new foam installed.
This is a solid rig and I have been very pro-active in servicing the van to make sure it is super reliable and as trouble free as possible. If new parts were being used, they are always factory OEM and/or Motorcraft replacements. I have never had an issue with the 6.0 diesel and besides wear and tear items (hoses, belts etc) it has been a true work horse. The van recently passed required diesel emissions here in Colorado (October 2020). I have included some of the more recent and highlighted service items below, I have most of the service records dating back to the first owner as well that will of course go with the sale of the van.
Interior:
  • Pioneer touchscreen stereo that has Apple Car Play, Sirius/XM Satellite Radio, reverse cameras (upper and lower) and more.
  • Two Ram mount bases mounted to the center console cup holder area
  • Various power points up front
  • Various USB and 12V power ports on both sides of the passenger area throughout the back with power key to disconnect from battery
  • Cup holders throughout cabin and on both rear chairs
  • Window and door shades (great privacy)
  • Front and Rear A/C and heat with ducts in the roof throughout van
  • 800-watt power invertor
  • Trailer brake controller
  • Two rear reclining swivel seats in the rear
  • Two captain’s chairs up front, driver side seat is a 6-way power seat
  • Entire van is well insulated, floor, walls, ceiling
  • Queen size platform (its slightly shorter than a queen)
Exterior:
  • Aluminess front winch bumper (12k pound Winch installed)
  • Aluminess rear storage bumper with dual swing outs with spare tire, storage box (door can be used as a table/workbench) and shovel and axe mount. Upgraded hinge pins and hardware
  • Massive Aluminess cargo rack with a ladder on the passenger side.
  • Two 6” led lights in the front bumper
  • Eight led lights across three sides of the roof rack
  • Two led lights in the rear bumper
  • 50” Led light bar facing forward up top.
  • Black nerf bars with diamond plate step
  • Bushwacker Fender Flares-Fenders (some fading from the sun is occurring)
  • Billet grill
  • Extendable large side mirrors
  • Class V Hitch
  • 48 Gallon auxiliary fuel tank is mounted after the rear axle; however, it is not hooked up.
Suspension and Drivetrain:
  • Dana 60 front axle from a Ford F350 (4.11 gears)
  • Dana 60 HD rear axle with limited slip (4.11 gears)
  • Rear Air Bags with Wireless controller
  • Newer Bilstein shocks front and rear
  • Newer coil springs up front
  • All new trackbar and sway bar bushing up front
  • New Tie Rod
  • New Ball joints and seals up front
  • Newer rear axle bearings
  • Full Transmission service (150 miles ago)
  • Both fuel filters recently changed
  • Brand new Motorcraft air filter installed
  • 17” Custom Rims with BFG All-Terrain KO2 LT285/70R17 tires (about 60% tread left)
Service History Highlights:
  • October 2020 @ 162,323 miles – Full Transmission service, New Turbocharger installed (old one was starting to lag from sticking vanes), Glow plug module replaced
  • August 2020 @ 157,250 miles – Replaced all 4 driver side fuel injectors, standpipe and dummy plug (injector #8 was failing so replaced all four as a preventive measure), Engine oil and filter changed, both fuel filters changed, new alternator installed, New ball joints and seals, New track bar bushings, new tie rod end
  • November 2019 @ 147,888 - Both Batteries replaced, Replaced Vacuum pump, Rear Axle bearings replaced (preventive), Replaced steering stabilizer
  • August 2019 @ 144,629 – New A/C Compressor and other A/C parts installed, and system recharged (A/C Compressor failed)
  • May 2019 @ 142,000 – Replaced radiator, new coolant hoses and serpentine belt
    November 2018 @ 135,000 – Four New BFG KO2 LT285/70R17 tires installed
  • October 2018 @ 133,961 – Both Fuel Filters changed, Oil Change with new filter, Full Transmission service, Drain and replace Coolant
  • Additional Service History...
Known Problems and What it needs:
  • Front windshield has a crack on the passenger side, I might have it fixed before sale.
  • Needs rear brake pads, might replace them before sale
  • Has a small oil pan leak – doesn’t drip but seeps a little over time.
  • Winch in the front bumper is installed however the wiring needs to be joined up front.
  • Oil pan bolt head is rounding off – I have new one to put in at next oil change.
  • Some of the interior is showing its age.
  • Aftermarket outside temp gauge in dash is going out
  • Some scratches here and there on the outside but nothing major
  • Some smaller dings on the rear doors from use but overall very straight
Like most 4x4 van owners I will be sad to see this monster go but my needs have changed, I need a truck to tow heavier loads and don’t have room to store the van so it will have to go to the next home.
Happy to answer any questions you might have. Thank You
