SOLD 2006 Toyota Tacoma TRD/OR Access Cab / Price Reduction
John90XJ
SOLD
2006 Toyota Tacoma TRD Offroad SR5 Access Cab
4.0 V6 / Auto / 4WD / factory rear locker / 6’ bed
185,XXX miles
This is a solid truck that has been well cared for and has seen backcountry miles throughout Nevada, California, Utah and the PNW. It’s been built for offroad travel and in that role it does very well. It’s also great to drive down the highway and returns ~17 mpg at highway speeds. It’s equipped with everything you would expect like cruise, tilt/telescope wheel, power locks, power mirrors, power windows, driver’s dead pedal, cabin air filter, multiple interior storage areas, multiple power sources, aftermarket Kenwood head unit with auxiliary input as well as USB thumb drive input. The AllPro components give it a lift height of approximately 2.5 inches over stock to fit the metric 32” tires. There is a mild engine tune, a cowl air intake and a dual outlet cat back exhaust. Two keys plus fobs. If you’re looking for an honest truck, properly sorted and fitted with well-chosen components to make it worthy of your adventure, you’ve found it.
AutoCheck report is clean, Nevada title is free & clear. Located in Cold Springs, outside Reno, Nevada. Flexible schedule. Possible delivery. Asking $20,995 Possible trades include motorcycles, Jeeps and other things that might be interesting. For further questions, photos please reach out at johnherrick1 at gmail.com
Maintenance & repairs since 8/2020:
Front wheel unit bearings, front brakes, driveshaft carrier bearing, steering rack & tierods, upper control arms, evap canister, driveshaft rebuild front & rear, rear pinion seal, new headlights, new taillights, new factory style grille, windshield. Open recall on factory leaf springs is null since springs have been replaced with aftermarket.
Additions since 8/2019:
AllPro front aluminum bumper with hidden winch mount
AllPro rear aluminum bumper with hidden 2” receiver
AllPro aluminum skid plate system
AllPro tubular steel rock rails with dimple die step platform
AllPro Modular Pack Rack with aluminum roof, L-track tiedown points
AllPro crossbed Action Packer rack with four 8-gallon tubs
AllPro chromoly Uni-Ball upper control arms
Bilstein 6112 coilover front shocks & springs
Bilstein 5100 series rear shocks
AllPro Expedition rear leaf spring packs
Baja Designs XL80 Sport white combo LED lights x 2 front bumper
Baja Designs Squadron round amber LED fog lights x 2 front bumper
Baja Designs S2 amber LED dust lamp, rear facing, rack mounted
Baja Designs S2 white LED work lamp, down facing, underside of rack
CruiserHead factory switches for all accessory lighting in dash
Rotopax 4.5 gallon fuel container, rack mounted
MaxTrax traction boards, rack roof mounted
Midland GMRS 15 watt mobile radio with mag mount antenna on rack roof
Bao Feng VHF/UHF handheld with mag mount remote antenna on rack roof
Mickey Thompson ATZ P3 265/70R17 tires, set of five, less than 2,000 miles on four, 5th new
Raceline Outlander 17 x 9, 4.50” backspacing / -12mm offset, Satin Greystone wheels, set of five
Warn VR Evo 12-S winch with synthetic rope, Factor 55 fairlead and FlatLink E
Flowmaster dual outlet cat back exhaust system
Odyssey PC1500 starting battery
Odyssey PC1500 Marine deep cycle on dual battery system with CTEK D250SA battery management system with MPPT controller, solar & wind ready
Painless Wiring Trail Rocker relay/fuse center for accessory wiring
Blue Sea 12 volt 15 amp outlets in bed area, x 2 plus factory 110 volt AC inverter
Artec Industries Odyssey battery mounts, x 2
ATH bedside reinforcement plates with tiedown points
ATH front bed corner tiedown points, not installed
Expedition Essentials radio/phone mounting system over center stack
RAM Mount X-Grip phone mount
Tribe16 seatback MOLLE panels, x 2
Candor Fab aluminum tailgate skin
Trail Head OffRoad cowl intake with factory filter box
Goldenbora
