**SOLD** 2008 Ford E450 4x4 Diesel Van - 45,600 Miles
TuskMetalworks
Price $42,500
VIN # 1FDXE45PO8DB26100
Ford E450 6.0 Turbo Diesel with 45,600 miles and 2,539 engine hours. Equipped with a top of the line Braun box with 6’ interior height. Vehicle is in nearly perfect condition and ready for any adventure as is or the perfect platform for a total camper buildout. All stock 6.0 diesel motor and the Quigley 4x4 system will easily tackle any type of off road terrain you throw at it. Fresh fluids and filters all around, so it’s ready to go cross country.
Stats
-45,600 miles.
-2,539 engine hours.
-Ordered as a Quigley 4x4 conversion straight off the showroom floor. 04/2008.
-All factory Ford parts used in 4x4 conversion.
-New Process 271 F Transfer Case. (Manual) High/Low range.
-4.56 Axle gear ratio. Easily cruises at 70-75mph.
-14,500 Lbs GVWR.
Front axle 5,000 Lbs GAWR (Coil spring)
Rear axle 9,500 Lbs GAWR (Leaf spring)
-HD Rancho Shocks all around.
-X4 Power Flash tuner.
-158” Wheel base.
-37 Gallon fuel tank.
-Dual alternator.
-Key fab entry, power locks, power windows, power mirrors, heated mirrors, cruise control, cold A/C.
-Vanner Control Module. AC power supply and charging unit. Model 20-1050CUL.
-Fully digital control panel. Controls all systems front and rear within the van and ambulance box. Heat/AC, lights, vents, etc.
-Braun Ambulance Box. 6’ interior height.
-Cab step through with door.
-Side sliding door.
-Blaupunkt speakers throughout Ambo box.
-Tons of storage.
-Onboard air compressor and tank.
-Tires 75+% tread life.
Cons
-Automatic side entrance folding step not working properly. Currently disconnected power.
Videos available upon request.
Price $42,500
Call or Text for more info.
# (320)282-8674
To find vehicle build info:
TRUCK 1 MM.jpg2 MM truck.jpg3 MM truck.jpg4 TRUCK MM.jpg5 TRUCK MM.jpgTruck 6 MM.jpgTRUCK 7 MM.jpgTRUCK 8 MM.jpgTRUCK 9 MM.jpgTRUCK 10 MM.jpg
iStan814
