(SOLD) 2008 JKU Rubicon for sale $16,500 -
Slowpoke
2008 Jeep Wrangler Unlimited (JKU) Rubicon, detonator yellow.
2nd owner, bought in 2010. Has the usual wear and tear of a Jeep. Well taken care of and thoughtful upgrades over the years. Top and doors come off and go on with ease. No water leaks. Clean title.
90k miles (no longer a daily driver)
6spd manual transmission
Freedom/hardtop (comes with additional over rear seat panel for use as a hard-bikini top, made from donor hardtop)
Interior:
Black leather interior (from a Sahara)
Leather shift boot and parking brake sleeve
Infinity sound system upgrade with subwoofer
Tuffy Flip-N-Lock Stereo Cover and tray (with combo lock)
Tuffy concealed driver side security drawer (with push button lock)
Tuffy Security Deck enclosure (trunk)
Weather Tech mats front & rear
1” RAM mount on center console and passenger grab handle
Ignition 12v cigarette lighter converted to dual 2.1 amp USB
Insane Audio JK-2001 head unit with TV tuner, front and rear rock cameras, Bluetooth OBDII dongle that connects to the head unit, and NavAtlas 4 channel amp
Exterior
3" Tera-Flex long arm lift
Fox shocks w/ external reservoir
35" BFG tires on 17" wheels, plenty of life in the tires
5.13 gears
Centerforce clutch (when installed, new clutch slave, seals, and flywheel machined as well)
AEV hood
Mopar cold air intake (CARB compliant)
Tow package with 4 & 7 pin connectors
Optima red top battery
Bushwhacker pocket fender flares
Mopar front bumper, Hella off road lights
Mopar rear bumper with tire carrier
Mopar rock rails
Relocated side mirror brackets (for doorless operation)
Rugged Ridge hood latches (fender flares trimmed down to fit latches)
replaced transmission, clutch slave cylinder, driveshaft joint, lower intake gasket, (11/16)
New water pump (8/17)
New radiator, coolant reservoir (6/18)
Replaced 2 Control arms (9/18)
Lower Control Arm brackets replaced (heavier gauge) (11/18)
Rubicon Express rear drive shaft
new brake pads (4/20)
SMOG late April 2020. New SMOG not required by new owner if purchased within 90 days.
Issues:
A/C inop
minor leather stitching pulling on driver’s seat
missing center rear seatbelt receiver
minor oil leak (<1 quart every 5k mile oil change)
Jonny Adventures
