SOLD! 2008 Lexus GX470 - $11,000 OBO - Grand Junction, CO
thatmaceguy
More Photos (Google Photos Album)
2008 Lexus GX470
JTJBT20X280168269
253,000 miles
Grand Junction, CO
$11,000 (open to offers)
Mods & Maintenance
2020 – 2021
• Power Stop Brake Calipers and GX460 Drilled & Slotted Rotors (thicker to prevent warp)
• Stop Tech & Apache Offroad extended braided steel brake lines
• Differential oil flush and replace with Mobil 1 Synthetic 75W-90 (front, rear, and transfer case)
• New power steering rack, pump, and reservoir
• Hayden Automotive 678 Transmission Cooler upgrade and transmission fluid flush.
• Apache Offroad Upper Control Arms
• OEM Lower Control Arms
• Dobinsons 1.5-3” IMS Suspension Kit (Long Travel Rear, Progressive Coils)
• Eimkeith Panhard Bar Angle Correction Bracket
• Lumen LED Low-beam Headlights
• Original CV Axles – Cleaned and rebuilt with CVJ high-angle silicone outer boots.
• Timbren Bump Stops
• Apache Offroad Rear Bump Stop Extension
• Apache Offroad Body Mount Relocation Kit
• Stock 4Runner TRD Off Road Premium Wheels
• Falken Wildpeak AT3W 285/70r17
• Cargo area gear drawer (custom)
2022-2023
• Coastal Offroad Front and Rear high clearance bumper kit
• Custom spare tire swing out with 4x Innovations hinge kit (1000lb bearings)
• Custom Sliders
• Ironman 12k Winch
• Power steering low pressure return lines modified to match new front bumper.
• Wiper fluid reservoir relocated to match new front bumper .
• Bison Cargo Area Shelf, Divider, and Window Panels
2024
• AISIN TKT-021 Water Pump and Timing Belt Kit
• Valve Cover Gaskets
• Bosch Oxygen Sensors (all 4)
• DieHard Platinum Battery
• OEM Radiator Fan Shroud
• New AC lines and recharge (ice cold!)
Other Notes
• Many other small mods and preventative maintenance.
• Oil changed every ~6 months with Mobil 1 High Mileage
Known Issues:
• Right-rear brake caliper leaks in winter (below ~30F). I have a new caliper but haven't had time to install yet.
• Door window weather strip needs to be replaced. I have the kit but haven't had time to install yet.
• Recent intermittent slow start. Starter is strong, so could be fuel pressure issue. Probably check valve letting pressure drop when parked. Inconsistent. Still runs very strong.
Psyph
