wesel123
Not riding as much as I used to. In all reality I haven't been on a decent ride in over a year, hate to see this awesome bike go to waste. All the specs are below. Had the front forks and rear shock serviced September of 2013 and it has yet to be ridden since. Only real thing it may need is a new chain, but thats debatable. The bike is pretty much the way the specs read although I changed the seat and added a Kind Shock Supernatural Remote-Adjust Seatpost (makes climbing much easier). It has a few small scrapes, as would be expected. Peddles shown will NOT be included.
Dropping to $1100!!!!
retail when new was around $4800.
It's a Medium frame.
TECHNICAL SPECIFICATIONS:
FRAME: Enduro M5 alloy, fully manipulated frame w/ ORE TT and DT, forged HT,
sealed cartridge bearing pivots, ISCG mount adj. geometry, replaceable
derailleur hanger, 150mm travel
REAR SHOCK: Specialized AFR Shock w/ Spike valve, air spring, adjustable rebound
and low speed compression, 7.875x2.25"
FORK: Specialized Future Shock e150SL, dual crown w/ integrated stem, 150mm
travel, rebound, compresion and travel adjust, 25mm thru axle, alloy steerer
HEADSET: 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge
bearing
STEM: Specialized Future Shock, 31.8mm clamp integrated w/ fork
HANDLEBARS: Specialized Enduro mid rise bar, 2014 alloy, 31.8mm, 6 degree up, 9
degree backsweep, 660mm wide
TAPE/GRIPS: Specialized thin lock on grip, dual density
FRONT BRAKE: Custom Avid Ultimate 7, hydraulic disc, 203mm rotor
REAR BRAKE: Custom Avid Ultimate 7, hydraulic disc, 185mm rotor
BRAKE LEVERS: Custom Avid Ultimate 7, hydraulic disc
FRONT DERAILLEUR: Shimano M581 LX, DMD, top swing, dual pull
REAR DERAILLEUR: SRAM X-0, 9-speed, mid cage
SHIFT LEVERS: SRAM X-9, aluminum 9-speed trigger
CASSETTE FREEWHEEL: Shimano HG-50, 9-speed, 11-34t
CHAIN: SRAM PC-971 w/ Power Link
CRANKSET: Shimano M762 XT custom for Specialized
CHAINRINGS: 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET: Shimano M762 XT custom for Specialized
RIMSDT: Swiss custom for Specialized X420, 24mm w/ eyelets, 32h
FRONT HUB: Specialized disc, 25mm thru axle, 32h
REAR HUB: DT Swiss custom for Specialized 370 w/ DT RWS QR, 32h
SPOKES: DT Swiss Competition 1.8/1.6mm
FRONT TIRES: Works Eskar, 26x2.3", 120 TPI, aramid tubeless ready bead, dual
compound
REAR TIRES: Works Eskar, 26x2.3", 120 TPI, aramid tubeless ready bead, dual
compound
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
bearing
compound
compound
