*SOLD* 2008 Toyota Tacoma TRD Sport Double Cab Long Bed 4x4 (DCLB 4wd TRD Sport) *SOLD*
tjalward
Truck has been sold. Thanks.
Black Sand Pearl (BSP), V6, Auto
91,350 Miles
$SOLD. Contact me through ExPo and I’d be willing to negotiate, especially if you can see in person. Located in Chandler, AZ. My name is Travis
Listed locally on Craigslist as well
https://phoenix.craigslist.org/evl/cto/d/chandler-2008-tacoma-trd-sport-double/7066970618.html
Custom, high quality build for dual purpose offroad - high speed running and low speed crawling, yet perfectly tame to drive every day with the whole family. IMO, sweet spot of model years for Tacoma - True LSD, full airbags, no traction control or terrain assist gizmos to get in the way, no secondary air injection garbage. Just a solid reliable truck with high quality mods. No mechanical issues of any kind, no rips, no drips, no squeaks, no problems, maintenance up to date. Currently registered, insured, passed emissions and clean title in hand. No accidents, no rust, always garaged. Never abused, low miles and tons of life left. Plenty of opportunity to make it yours for years to come. You won't be disappointed seeing it in person. Carfax available.
Chassis:
• XD Revolver 17x9 wheels (all 5)
• 315/70/17 (35”) Nitto Trail Grappler load range D with 12-15/32nds (60-70%) remaining. Full size spare on Wilco Offroad Tire Gate swing out
• Factory true mechanical limited slip differential
• Custom full-length square tube sliders go tire to tire, with flares front and rear, made for this truck and welded to frame
• Aluminum front skid plate integrated into the custom pre-runner style bumper
• True limited slip differential
Front Suspension:
• Pro Comp lift - control arms at mild angles and very smooth ride at higher lift height
• King extended 2.5” remote reservoir coilover shocks with 600lb springs
• King 2.5” smooth body remote reservoir with compression adjuster secondary shocks
• Total Chaos lower control arms (LCA) with uniball outer and grease-able poly inner pivots
• Total Chaos upper control arms (UCA) uniball outer and heimed inner pivots for precise alignment adjustment
• Total Chaos secondary shock hoops
• Very flat/straight axles, good CV angles for durability
• 11” + front wheel suspension travel
Rear Suspension:
• Custom Alcan leaf springs made for this truck
• Shackle flip, custom length shackles and custom shackle mount
• U-bolt flip
• King 2.5” double bypass 14” piggyback reservoir shocks
• Custom lower mounts level with axle for rock clearance
• Custom in the fender (not through the bed) shock hoops
• King 2.5” diameter hydraulic bump stops on custom mounts and axle bump pads
• Drive shaft angles perfect, no vibrations at any speed
• No lift blocks or spacers!
• 12” + rear wheel suspension travel
Body & external:
• Black Sand Pearl paint in great condition, few minor flaws to be expected in an offroad truck
• Fiberglass front fenders, paint matched
• Custom one of a kind front and rear bumpers by Raven Industries
• Integrated skid plates
• Winch ready
• Rear utilizes full OEM receiver hitch for factory tow rating
• Wilco Tire Gate to hold full size spare, can be flipped to hold tire in bed or behind it
• High lift jack mounted in bed
• Mesh grill
• Bed floor mounted lockable tool box (where spare tire was)
• Working AC inverter and 120V outlet in bed
• Shorty antenna
• Hood scoop mod (opened up for air flow and hot air escape)
• Shaved and de-badged
• Black out (tint, tail lights, 3rd brake light, headlight surrounds)
• Have original tail gate to include if buyer wants
• Can include ReTrax roll and lock bed cover if buyer wants
Interior:
• Kenwood Excelon DNX 9990 HD Media center with navigation and BT hands free calling
• Boston component and coaxial speakers in doors with crossovers
• Door tweeter upgrade with ********* adapters
• 12” Alpine subwoofers behind back seat, with custom enclosures
• Separate Alpine amplifiers for subs and door speakers mounted between sub enclosures
• Bass adjustment knob for amplifier gain on dash
• All wiring done right with large AWG copper welding cable, fused, distribution blocks, etc.
• Overhead temp and compass display are working
• All switches are triggering relays in engine bay
• No tears, wear or stains in the interior, great condition sport seats
• Map light mod, map lights come on with dome light but still switchable separately
• Integrated microphone and satellite antenna
• Tacoma all weather rubber floor mats front and rear
Lighting:
• Spyder HID / xenon headlights, black surrounds
• LED 30” dual row light bar on behind the grill custom mounts
• LED pod lights in front bumper (with anytime fog light mod)
• LED flush mount pods in bedsides
• LED backup lights on switch
• LED bed/cargo lights
• LED 50” radius roof light bar and relentless roof mounts - Can include if buyer wants to put holes in drip molding to mount it
Engine and Drivetrain:
• V6 engine, 5 speed automatic transmission
• Remote start alarm
• K&N cold air intake
• Throttle body spacer
• OEM exhaust (super quiet on highway and gained performance compared to insane loud 3” exhaust that was on it previously). Can give 2.5” magnaflow muffler to splice in if buyer wants it)
• Fresh fluid changes (engine oil, diffs, transfer case, transmission, brake fluid and power steering)
• Fresh battery from Costco with 2 years remaining on warranty
• TPMS light disabled with yellow wire mod behind glove box (there are no pressure sensors in wheels)
• TRD performance brake pads
• No noises, clunks, rattles, no CV popping, no drive shaft vibrations. Drives very nice!
Selling because I need space in the garage. Don’t use the truck anymore and want to put money towards other projects, time to move it along to someone who will use it and enjoy it.
Trades – yes, for cash
Thanks for looking.
tjalward
Looks like since I put the pictures in the text instead of attaching them, you need to hit the "click to expand" link in the first picture to see the pictures. I can provide more pictures as well if specific questions or concerns are raised.
DanoWall
