**SOLD** 2012 Nissan Xterra 4x4 - $7,000 - Austin TX
mahlerous
Here's your chance to buy a SOLID Xterra mostly stock, in one of the BEST model years.
Includes a decent discount and a few overland mods to get you going off the beaten path and exploring!
Way less expensive than a Toyota or Land Rover.
By 2012 Nissan completely resolved problems of previous year Xterra's like SMOD and timing belt failures.
This 2012 is going to go and go and keep going, with no issues, as long as standard maintenance is performed!
Ready for YOUR CHOICE of bumpers, sliders, plates, and auxiliary lighting. Tires are good to go wherever you desire👍
If you're reading this then you know these trucks have a lot of potential for modifications, like a Titan suspension swap (major) or V8 swap.
Just like Jeeps they can rock-crawl and offroad with the best of them, even with stock IFS.
Everything is disclosed below. Good price for what you get.
CLEAN BLUE TEXAS TITLE
Strong 4.0L V6
232K mi
Austin TX
OVER $6,000 EXTRAS:
* Optima Redtop battery ($300)
* Viper remote start & alarm ($300)
* Gobi Ladder ($450)
* Front Runner Slimline II complete roof rack kit ($1600)
* AVS Ventvisors all 4 windows ($70)
* Bosch Icon Wiper Blades ($60)
* CoverKing custom windshield sun cover ($50)
* CoverKing ballistic custom seat covers ($500)
* Lloyd's floormats front row, back row, and cargo ($500)
* McMaster rear-hatch strut mod (extended length and high capacity) ($90)
* Reverse camera
* Alpine touchscreen head unit with Carplay & Bluetooth ($300)
* Bilstein 5100 shocks 2-inch lift and Ironman AAL rear ($600)
* Goodyear Wrangler Duratrac tires 285/75r16 (33") only 1 year old ($1500)
* Tow hitch with 4-pin wire harness
* "Anytime" fog-lights mod: OEM fog-lights with dash-mount control, separate from stalk switch, able to turn ON independent of running lights and headlights, which cannot be done using OEM stalk switch. ($200)
* Vosla 9007 headlight bulbs from Daniel Stern Lighting ($50)
HISTORY:
230,000 - cabin filter
230,000 - air filter
202,000 - brake fluid flush
202,000 - cooling system flush
202,000 - new valve cover gasket
201,000 - new passenger seat belt assy
199,000 - new oil cooler o-ring
199,000 - new drive/serpentine belt
190,000 - steering fluid flush
190,000 - 4 wheel alignment
159,000 - 4 wheel alignment
156,000 - new ABS sensor front passenger
70,000 - transfer case oil change
70,000 - transmission oil change
70,000 - rear differential oil change
70,000 - front differential oil change
70,000 - brake fluid flush
SPARES:
* OEM Hood deflector (new in box, not installed)
* OEM Sunglass holder with maplight (not installed, available for purchase)
* OEM Low-profile rear-seat headrests (not installed, available for purchase)
* OEM Stalk switch for foglight control (not installed, available for purchase)
* OEM Air filter intake duct - spare for modifying "airbox mod" (not installed, available for purchase)
* OEM Dash cap - spare for modifying "RAM mount & ICS tray" (not installed, available for purchase)
* OEM Center arm rest (spare)
* OEM Serpentine belt (spare)
* OEM Tensioner (spare)
* paint pens
* brake pads
* window regulator (spare)
* ABS sensor (spare)
PENDING:
Hail damage on driver side, hood, and roof. All glass is good or was replaced.
1 rock chip (pencil eraser size) in (new) windshield.
Small dent in rear bumper.
Driver window control occasionally inconsistent and slow. (have new replacement in box)
Driver windshield spray nozzle partially clogged. (have new replacement in box)
VERY slow power steering fluid leak. (truck comes with extra quart of Dexron III/Mercon ATF to top off at every oil change 😊)
quigleyth
