Hello:
Hello:
Selling my 2013 Land Cruiser LC200, with 159,xxx miles, $42,500 without RTT and $45,000 with RTT & Awning. The car was originally from North Carolina, and has been with me in St. Louis for 3 years. I have done an extensive amount of preventative maintenance on it and it is in extremely good mechanical condition. The truck has a 1" IronMan Foam Pro Cell lift all around, but the front has the OEM strut spacers, to almost level it out. It depends on the amount of air in the rear airbags, but with 15 PSI in the rear, it still has the original rake, but not as pronounced. I always get asked about the truck, either about the Dobinson's Snorkel or the RoofNest Condor XL roof top tent (RTT). The Condor XL is rated at up to 4 adults, but I find it is perfect for two adults and two kids. Essentially, when unfolded, the mattress is equivalent to a California King size mattress.
Some preventative maintenance and items below:
11/29/21 - 1) new left front wheel bearing, 2) new right outer tie rod end, and 3) alignment.
9/01/21 - 1) new Ironman Foam Pro Cell 1” lift and SPC Upper Control Arms. 1” all around, but kept the Toyota OEM strut spacer in front to level the truck. 2) added AirLift airbags on the rear springs.
05/07/21 - 1) new radiator and drive belt, 2) replaced water pump, 3) replaced thermostat, replaced belt tensioners, 4) idler pulley, 5) replaced fan clutch, pulley, 6) replaced upper and lower radiator hoses, 7) replaced PCV valve, 8) replaced air filter and cabin filter.
10/01/20 - Roofnest CondorXL Hard shell Roof top tent mounted on Rhino Rack roof rack (have stock) and Rhino Rack Awning (unused).
9/11/20 - 120k mile service (140,000 miles on vehicle) to include 1) new Denso spark plugs, 2) replaced transfer case fluid, 3) replaced front and rear differential fluid, replaced automatic transmission fluid, and added Toyota OEM front strut spacers.
9/01/20 - 1) new Phillips Extreme HID headlights, 2) new yellow LED fog lights, 3) LED daytime running lights & high beams, 4) new interior LED lights.
8/01/20 - Added (5) Toyota TRD Tundra Rock Warrior rims with Falken Wildpeak tires 285/70-17, including the spare. Added weather tech rear cargo Mat. Removed and stored third row seating (extra seats included).
Mechanically, car is excellent. Interior, very good to excellent, with some typical wear on the driver's side seats. Exterior, good to very good, some rock chips, a small repaired small ding on the rear tailgate and passenger side rear wheel well. The tires should be replaced soon, as they are near the end of their life. Two issues when buying Land Cruisers - the KDSS valves should not be frozen (mine work fine) and the car should not have rust, other than some surface, underneath (no rust under this one).
More Photos: https://drive.google.com/drive/folders/1qLgvFZ472k_4zNGvH3aVyNOxjLLrD7P4?usp=sharing
Contact: ronstar2@gmail.com or 314-709-7612
Thank you,
Ron
Hello:
Thank you,
Ron
