Trailer+tent is being sold by the original owner (purchased in April, 2017 and used for 4 years). Cleaned after every trip and garage kept for the life of the camper. Used for 13 trips, has travelled a distance of 7,100 km. Asking $8500 Canadian (or ~ $6,750 USD).
Trailer is located in Calgary, Alberta, Canada.
No known defects.
The trailer specs:
- 4' x 7' steel trailer built by Trailerman out of Abbotsford, B.C.
- Dry weight ~ 1,110 lbs
- GVWR (Gross Vehicle Weight Rating) 3,000 lbs
- 7-way RV Blade wiring with electric brakes
- Storage volume in trailer ~ 50 cu. ft.
- Overall length: ~12', Width (fender to fender): ~70", Height (including stowed tent): ~52"
- Swing-away tongue jack with swivel dual castor - 2" ball coupler
- Rear stabilizer jacks (1,000lb capacity each) - 15 inch steel powder coated wheels and highway rated radial tires
- Leaf springs
- Side swinging tail gate with lockable over-centre latch
- Steel floor and 21" sides - 3,500lb idler axle
Safety chains
- License plate lamp
- LED lighting
- 2" rear receiver mount (great for bike racks)
- Spare wheel and tire (never used)
- DeeZee Poly Triangle Box mounted to trailer tongue to store tarps, chocks, tools, etc.
The tent specs:
- OZtrail Ridgeline Zenith
- Approximately 200 square feet of overall space including main bed, tent and awning.
- Sleeps a family of 4-5 comfortably
- Full-size queen bed (60" wide x 80" long x 6" thick). All beding including pillows can be left right on the bed and stored there when the tent is closed up (picture shows all the bedding we had on the mattress when packed up).
- Floor area inside tent is 9' long x 7' wide x 7-8.5' high
- No-fuss trailer tent set-up with built in support frame of heavy duty galvanized poles. Main tent can be easily erected in less than 10 minutes.
- No-See-Um mesh on windows for complete insect protection.
- A double silver coated 340 GSM SatProofTM 800+ poly cotton canvas roof with the waterproong compound saturated (not coated) into the canvas. Double stitched and reinforced at all stressed points.
- 340 GSM SatProofTM 600+ Canvas Ripstop walls, double stitched and reinforced at all stressed points.
- Insulcell triple layer insulated roof keeps you cooler while rolled edge design protects you from driving rain.
- Reinforced PVC floor plus all seams are welded not sewn, to keep the elements out.
- Zip down dust cover: heavy duty coil zip and Velcro flap to reduce dust getting into your camper when travelling. Constructed from heavy duty reinforced PVC with welded seams for the ultimate in waterproofness.
- Tilt Equipped: comes with a complete gas strut system to allow the whole tent tilt and open up allowing access to the trailer for effortless packing and unpacking.
- Under-bed access hatch to trailer with gas strut assist
- All windows have internal window flaps. This allows you to keep the windows open and yet if it starts raining you do not have to go outside to close them up.
- Bedroom Privacy Curtain: for extra privacy to separate the bedroom and the living area. Features a screen mesh or solid panel that can be easily removed.
- Heavy duty pegs and ropes: all pegs are heavy duty with the main pegs being extra heavy duty. All guy ropes use steel runners with trace springs. Double guys and springs supplied for the awning corners.
No known defects.
The trailer specs:
- Leaf springs
Safety chains
- LED lighting
The tent specs:
