SOLD: 2016 KTM 350 EXC-F - 156 hours/3940 Miles
N.Y.X.
2016 KTM 350 EXC-F On/Off Road Enduro. Street legal with clean Colorado title in hand. Currently registered/insured.
2nd Owner - 1st owns Santa Fe Harley Davidson and was dealer maintained. Meticulously Maintained. Mostly used to explore passes and forest roads while camping and puttering around town.
$6,500 or best reasonable offer.
Interested in trading for a slide in, short box, pop up, truck camper.
~Hand Guards
~Power Commander
~New Brake Light
~Misc Spare Parts
~Tube, Oil, Coolant and Oil Filter
~Pro Taper Bars
~Cell Phone Holder
2016 KTM 350 EXC-F Specs:
  • Engine: Liquid-cooled DOHC single
  • Displacement: 350cc
  • Bore x stroke: 88 x 57.5mm
  • Compression ratio: 12.3:1
  • Fuel management: Keihin EFI w/ 42mm throttle body
  • Ignition: Keihin EMS
  • Lubrication: Pressure lubrication with 2 oil pumps
  • Transmission: 6 gears, claw shifted
  • Clutch: Wet multi-disc DDS-clutch, Brembo hydraulics
  • Starting: Electric and kick
  • Battery: 12V, 4Ah
  • Silencer: Aluminum w/ USFS-approved spark arrestor
  • Final drive: X Ring 5/8 x 1/4 inch chain
  • Frame: Central double-cradle-type 25CrMo4
  • Subframe: Aluminum
  • Handlebar: Neken, Aluminum 28/22mm
  • Front suspension: Inverted WP 4860 MXMA PA forks; 11.8 inches of travel
  • Rear suspension: Single WP PDS 5018 DCC shock; 13.2 inches of travel
  • Front brake: 260mm disc
  • Rear brake: 220mm disc
  • Front rim: 1.60 x 21 inches
  • Rear rim: 2.15 x 18 inches
  • Front tire: 80/100-21; Metzeler Six-Day
  • Rear tire: 140/80-18 Metzeler Six-Da
  • Rake: 26.5°
  • Triple clamp offset: 0.87 inches
  • Wheelbase: 58.35 ± 0.4 inches
  • Ground clearance: 13.6 inches
  • Seat height: 38.2 inches
  • Tank capacity: 2.25 gallons
  • Weight Without Fuel: 241 pounds
