nockturno_j
Selling my 2017 Toyota Tacoma Sport 4x4 as the family is growing. Putting one car seat with a 85 lb Golden Retriever was tight enough, but planning to add a second car seat back there is a no go. We will be looking into getting a full size truck or SUV and switch travel trailer RV camping once kid 2 is here. We thought about towing with the Tacoma, but cabin space is a no go. Will definitely make the wife happy, and control the elements for naps and bedtime routine when outdoors. Selling the truck is something we did not want to do, as this truck has been great without a single problem. The truck has a solid foundation with a clean canvas and can be built up to your liking, or just turnkey ready to go off-road and camp wherever the path takes you. Keeping the truck as a total package, and would rather not part out. Located Northern Virginia
The Truck Base:
- Single and sole owner, bought with 14 miles from the dealer. Driven by me as no one can really drive manual transmission anymore. Window sticker still in glove compartment.
- Zero issues
- 72,xxx miles. Majority all highway miles as my work commute use to be 80 mile roundtrip. Currently only gets driven 100-300 miles a month.
- TRD Sport 4x4, with limited slip
- 6 speed Manual transmission
- 4.10 gear ratio stock
- Bluetooth Tech
- Navigation Radio
- Sunroof
- Cruise control
- Tow Package
- Multi-ball hitch on it. Lost the hitch pin lock key, key lock is an easy break, but have not needed to take it off. Towed only once for moving 4 years ago with a small U-Haul trailer.
- Maintenance performed by me past the 25k miles. Following user manual for recommended maintenance. Oil Changes, drive shaft lubrication, ensuring all fluids are at correct level, air filters, etc.
UPDATED and UPGRADE Parts:
Suspension:
- Front: King Shocks 2.5 adjustable coilovers, w/ adjustable remote reservoir
- Front: Total Chaos uni-ball UCA. Lubrication completed every oil change
- Rear: King Shocks 2/ adjustable remote reservoir
- Rear: ARB/OME Heavy Duty Dakar Leafs
Wheels:
- Rim: SCS SR8 17x8.5 -10mm offset
- Tires: Falken Wildpeak AT3 275/70/R17. Driven 20k miles, rotated every 5k miles. Rated for 55k miles.
Interior:
- Expedition Essentials USB powered accessory mount with fast charging powered USB
- Ram mounts included
Starter Battery:
- NorthStar Battery - NSB-AGM27F
Auxiliary Power:
Secondary Battery System (Not connected to starter battery). This system is built entirely isolated to avoid any ghost drainage from the starter. Also modular as I liked to keep the bed empty if we did road trips to visit family.
- Deep cycle Marine battery (needs a good overnight charge as the truck mostly sits in the garage now)
- 100 W Solar Panel Mounted on Roof Rack
- Custom made power inverter box. Contains the PWM, fuses on each input and output for solar to charge battery, connection for the fridge, USB outlets for phone charging. A power inverter can be installed if desired.
Bed:
- Bedmat
- Cut out a piece of birchwood, same material and thickness as goosegear, and was going replace bedmat to secure fridge and battery down properly. Did not continue with project. Can provide if wanted.
- SwingCase Storage Box, Driver side.
Overall Truck:
- AluCab Canopy. Lights not connected. Easy install to run to auxiliary battery or main battery.
- Baja Utility Roof rack
Camping Gear:
- Tepui Autana 3 w/ Annex and floor. Bought Used. Previous owner had slept in it 10 nights. We slept in it 15 nights. Updated the velcro straps and added buckles.
- Oztent foxwing 270 awning w/ extension panels.
- ARB Fridge
Asking Price: $40,000 OBO.
Waiting for temps to go up end of week before to wash/clean and take more pictures.
The Truck Base:
- Zero issues
- Bluetooth Tech
- Navigation Radio
- Sunroof
- Cruise control
- Tow Package
Suspension:
Wheels:
Interior:
Starter Battery:
Auxiliary Power:
Bed:
- Bedmat
Overall Truck:
Camping Gear:
- ARB Fridge
