**SOLD** 2019 Escapade Backcountry - 5.5’ x 10’ Camping Trailer MN
Honch
2019 Backcountry Mini-Camper build completed and picked up August 5, 2019. Camper built by Escapade Campers, Hutchinson, MN.
Aluminum sides with 3,500 pound Timbren Axle-Less Suspension with easy lube hubs and 16" of ground clearance.
Need to make a change in lifestyle due to health concerns and needing more room for three grandsons under age seven.
Asking Price: $10,500 US
Clear title in hand.
Condition: Excellent except a small ding in the rear galley door. You can't see it from a distance and up close it just blends in with the other reflections.
Specifications:
Total Weight: 1,300 pounds
Total Length: 15'
Total Width: 86"
Cabin Length: 10'
Cabin Width: 66"
Max height to top of roof rack: 77"
Roof Rack Capacity: 500 pounds
Ground Clearance: 16"
Tongue Weight: 150 pounds
Interior Cabin Length: 83"
Interior Cabin Width: 64.5"
Max Ceiling Height: 45"
Features
Height adjustable 2" ball coupler
4 prong trailer plug
Tongue mounted cargo carrier
Full front black diamond plate stone guard
Rubberized under body coating
Aluminum exterior panels
Driver and passenger side doors with windows and screens
Driver and passenger side windows with screens
LED trailer lighting
12v group 31 deep cycle battery mounted in driver side of rear galley to lessen tongue weight, protect from the elements and to protect against pilferage.
3,500 pound Timbren Axle-Less suspension with easy lube hubs
16" ground clearance
15" black steel rims
205/75/15 radial trailer tires with matching spare
Black aluminum diamond plate non-step fenders
Rear BAL leveling jacks
Rear 2" accessory hitch
Passive air vents above windows
Kayak & Canoe tie downs located on all four exterior corners of roof
1.25" steel powder coated roof rack crossbars - 500 ponds capacity
3/4" UV finished Maple wall structure
Full radiant barrier insulation
Woodgrain padded vinyl flooring
Solid galley wall with rear upper corner shelves
Dual LED interior cabin lights
12v & 120v 15 amp power plus on-board battery charger
MaxxAir deluxe vent fan with built in rain shield.
Fan is reversible and can be run with rain shield closed.
Queen tri-fold mattress (4" thick x 80" long x 60" wide)
Upgraded:
Upper front cabinets
Air conditioning - 5,000 BTU
Galley
Large galley door on rear of cabin
Counter top & upper galley shelf
Ceiling mounted LED light
110v pigtail plug with exterior hookup located under the center galley shelf on the driver side
Cabin:
Escapade Camper's Photo - Backcountry Inside Passenger Side Measurements.jpg
Psyph
