SOLD: 2019 Radrover E Bike(s)
FlagRS
Gone to the dogs.
Two identical 2019 Radrover E Bikes SOLD. Both bikes are in Excellent Condition both cosmetically and mechanically.
For a detailed review of this exact model visit: https://electricbikereview.com/rad-power-bikes/2019-radrover/
ELECTRIC BIKE CLASS: Throttle on Demand (Class 2)
TOTAL WEIGHT: 68 lbs (30.84 kg)
BATTERY WEIGHT: 7.7 lbs (3.49 kg)
MOTOR WEIGHT: 8.7 lbs (3.94 kg)
FRAME MATERIAL: 6061 Aluminum Alloy
FRAME SIZES: 18 in (45.72 cm)
GEOMETRY MEASUREMENTS: 18" Seat Tube, 30.5" Stand Over Height, 22.5" Reach, 30.5" Standover Height, 33" Minimum Saddle Height, 28.5" Width, 75" Length
MOTOR BRAND: Bafang, RadRover Specific
MOTOR TYPE: Rear-Mounted Geared Hub
MOTOR NOMINAL OUTPUT: 750 watts
MOTOR TORQUE: 80 Newton meters
BATTERY BRAND: Samsung 18650 35E 3500mAH 13S4P Configuration
BATTERY VOLTAGE: 48 volts
BATTERY AMP HOURS: 14 ah
BATTERY WATT HOURS: 672 wh
BATTERY CHEMISTRY: Lithium NCA (LiNiCoAlO2)
CHARGE TIME: 6 hours
ESTIMATED MIN RANGE: 25 miles (40 km)
ESTIMATED MAX RANGE: 45 miles (72 km)
iStan814
