JumpJ
Why the sale - Our 4x4 Sprinter pictured, I think, will not pull it. We are going to upgrade into a larger vehicle.
It is at RVs of America and being gone through as I write this. Has heated tanks for winter camping. Listed on RV Trader but will sell it for $40,000 and you can see it in Utah until the 23rd then it probably will move to San Diego area.
We used it once to Moab but had the wrong tow vehicle. Dumped with snow-stayed at the RV park and returned home to Boulder. Needs nothing and you don't need to wait for a 21. Feel free to look at the listing in RV Trader as well https://www.rvtrader.com/listing/2020-Black+Series-CARAVAN+HQ17-5014606025/?cmp=email_rv_paa_posted
We bought the Black Series because it truly is ideal for the family with 2 bunk beds in the back. Quean bed for the parents and the dinette converts into a bed as well if needed. Two kitchens-inside and out. We added tank heaters.
Keep the kids entertained with two drop down DVD players!
You will love the quality of this trailer. This has everything you could ever need.
__________________
SLEEPS: 5
MAX EXTERNAL BODY LENGTH : 24 ft **polyblock to spare tires**
MAX EXTERNAL WIDTH: ft 8in **including rock sliders on sides**
MAX EXTERNAL HEIGHT: 10ft 5in **AC to ground**
UNIT WEIGHT: 6,750 lbs
TONGUE WEIGHT: 700 lbs
MAXIMUM TRAILER CAPACITY GVWR: 10,000lbs
___________________
INDEPENDENT SUSPENSION:
*Black Series has worked tirelessly to develop the most robust independent suspension system available. Custom designed and engineered trailing arms allow each wheel to move independently, allowing for a smoother, more stable ride whether on the highway or on rough terrain. The quad shock design spreads the load across four shocks instead of two, allowing for a smoother ride, safer handling, and longer shock life.
-4 HEAVY DUTY ARTICULATING RED CONTROL ARMS
*Suspension engineered and Load Tested at 40,000 lbs Per Control Arm
-(x4)Dual Shock Absorbers And Coil Springs per control arm.
-Limiting chains
POLYBLOCK HITCH-Full 360° rotation and unrivaled articulation means you can tackle even the most demanding trails.
-ARD XO Swing Away 10 Jockey Wheel
-7 pin connector
-anderson power connector
-Emergency Brake for cocking tires
CHASSIS:
-Hot Dipped Galvanized Tubular Steel
*Made From RHS 4 X 2 , 0.15 Wall Thickness -0.24 Supporting Plates For Extra Strength And Durability.
**WHAT IS HOT DIPPED GALVANIZATION? It is the process of coating iron and steel with zinc, which alloys with the surface of the base metal when immersing the metal in a bath of molten zinc at a temperature of around 449 °C (840 °F). Galvanizing protects steel by acting as a barrier between steel and the atmosphere. Galvanizing protects steel by acting as a barrier between steel and the atmosphere, which means that when a galvanized coating is damaged and steel is exposed to the atmosphere, zinc can continue to protect steel through galvanic corrosion.
-4X Stabilizer Legs
-Facing Recovery Shackles - Rated To 9,000 lbs.
-4 Rock Sliders for added protection when off-roading
WHEELS: 16 Aluminum With A Satin Black Powder Coated Finish.
-TIRES: 265 X 75 X R 16 Off-Road All Terrain Tires.
-Rear tire rack with 2 spares
-BRAKES: 12 Electric Tow Brake With Mechanical Handbrake.
-EMERGENCY BRAKE to effortlessly chock tires instead of placing blocks under each tire.
-Breakaway System Car Attachment Provided
__________________
SLEEPS: 5
___________________
-Limiting chains
-7 pin connector
CHASSIS:
-4X Stabilizer Legs
