SOLD 2020 Winnebago Revel 44E
carolinakim
Purchased new in April 2020 for travel between New England and the FL Keys. It's never been off road or in snow. 11,011 miles. Pebble Gray exterior with Gravity Gray/Silver Springs interior. A/C and performance stylized wheels with BF Goodrich all terrain tires. Asking $139,000.
https://www.winnebago.com/models/product/motorhomes/camper-van/2020-revel?specifications=true
Mercedes-Benz® Sprinter Chassis
3.0L 6-cylinder, 188-hp, turbo-diesel engine, 7G-Tronic automatic transmission, 220-amp. alternator
On-demand 4WD w/Hi/Lo range, electronic stability, and traction control
4-wheel ABS brakes
Trailer Hitch6 5,000-lb. drawbar/500-lb. maximum vertical tongue weight
7-pin wiring connector
Electrical: AC/DC load center/converter
3 deep cycle Group 31 batteries (AGM maintenance free)
Coach battery disconnect system
Dual-battery charge system
Exterior AC receptacle
30-amp. power cord
Solar panel/battery charger
2,000 watt AC/DC inverter
Plumbing: Exterior Service Center city water hookup/tank diverter valve, drainage valves, sewer hose valve and exterior wash station w/pump switch, 10 ft. sewer hose, holding tank compartment
Winterization Package with valve and siphon tube
On-demand water pump
Galley drain pump
Insulated/heated gray water holding tank
Insulated/heated fresh water tank
Potable water tank
