Up for sale is our 2022 Flagstaff E-Pro 15TB camper/RV. This unit has all of the options from the factory including the Pro Roof Rack and removable ladder, 190 watt solar panel, tongue mount bike rack, off road package with tires and lift. Below are the included features from the manufacturer. We have also done some mods to the camper, such as changing the cabinet doors from horizontal opening to vertical opening so you don't hit your head on the open doors. We also reinforced the fridge so it did not fall out while going off-road. Also with the fridge, we added a digital thermostat as well as a 12v fan system that helps the fridge keep temperature while it is hot outside. There are a few other extras as well such as two larger AGM batteries and a new metal lock box, a paper towel holder, shoe holders in the entry, key ring and organizer.
We also modified the bed to be an east/west full size bed and added a lagun table. This includes a tempur-pedic memory foam topper. This setup is easily convertible back to the original twin/king bed setup by removing the foam and table. Please let me know what you think and if you would like to come see the camper. Located in Aurora, Colorado.
Length: 15'10"
Unloaded weight: 2667lb
Height: 10'3"
Fresh Water: 30gal
Gray Water: 15gal
Black Water: 15gal
4 Frame Mounted Stabilizer Jacks
Fold Out Entry Steps
Roof Ladder
Magnetic Baggage Door Catches
Outside Shower
Teton All In One Wi-Fi Booster/LTE Prep & Antenna
Outside Griddle with LP Hookup
2 - 20# LP Tanks (both almost full)
Ground Solar Prep
Outside Speaker
190 Watt Roof Mount Solar Panel w/ 1000 Watt Inverter
Power Awning
Polished Alloy Wheels
Tinted Bonded Frameless Windows
Heated Holding Tanks
2 5/16" Hitch Receiver
13,500 Roof A/C
Roller Shades
20,000 BTU Furnace
12V Entertainment TV w/stereo
Aluminum Cage Dinette Bases & Beds
6 Sided Aluminum Cage Construction
Vacuum Laminated Roof and Walls
5/8" tongue and groove plywood flooring
Interior & Exterior Azdel Sidewall Construction
Torsion Axle, Rubber-Ryde Suspension
Tire Pressure Monitoring System
Pre Wired for Backup Camera
Spare Tire W/ Carrier
15” Mud Rover Radial Tires and Lift Kit
Power Tongue Jack
12V Refrigerator
Microwave
Recessed Cooktop W/ Flush Mount Cover
Convection Microwave
Maxxair® Ventilation Fan and Vent Cover
Quick recovery Gas/Electric Water Heater
Shower Miser Water Saver
360 Siphon Cap on Black Tank
Foot Flush Toilets
Tongue Mount Bike Rack
Pro Rac Mounting Bars w/ Removable Ladder
Bluetooth System Control Panel
Spare Tire
Hidden Hinge Cabinet Doors
Length: 15'10"
Height: 10'3"
Fresh Water: 30gal
Gray Water: 15gal
Black Water: 15gal
Roof Ladder
Outside Shower
Ground Solar Prep
Outside Speaker
Power Awning
13,500 Roof A/C
Roller Shades
20,000 BTU Furnace
Power Tongue Jack
12V Refrigerator
Microwave
Foot Flush Toilets
Spare Tire
