Sold: 6’ Roamin Chariot pop-up truck camper
Tbrim
2003 Roamin Chariot
Located in Sandpoint, Idaho
$5,500
Aluminum frame wedge style camper that weighs less than 600 lbs.
It is intended for a midsize 6' truck bed.
It is water tight and in great condition for its age.
I installed a 6,500 BTU propane furnace(propex hs2000) that is externally-vented heat and has a digital thermostat to keep the temperature dialed. I have camped on mountain passes where it was -10 outside and stayed plenty warm in the camper.
It has a couple usb ports for charging gear and led lights that all run off a deep cycle battery.
The bed is 4" memory foam full size mattress that has been slept in less than 6 times.
I put a birch counter in the corner that I used for cooking and has a quick connect propane fitting in the wall so that you can hook up your camp stove easily. The panel on the back wall is a metal pegboard used for hanging kitchen utensils.
Includes two cable camper jacks.
IMG_0164.jpgIMG_0176.jpgIMG_0177.jpgIMG_0169.jpgIMG_0168.jpgIMG_0170.jpgIMG_0173.jpgIMG_0167.jpgIMG_0171.jpg
Goldenbora
