((SOLD)) 97 4RUNNER
toy_tek
SOLD
1997 Toyota 4Runner SR5 4x4 auto - double locked (ARB) & lifted
2nd owner, I purchased in 2002 w 59k miles.
Zero rust rot
Plenty of AZ pinstriping & brush polishing, however paint is not peeling anywhere.
260,xxx miles
Not a parking lot queen - but this truck will take you through Baja tomorrow.
Has been well maintained, mostly OEM Toyota parts throughout.
No squeaks or rattles
*SUSPENSION*
3” lift
-Front: ICON 2.5 coil overs (front)
-Rear: LandCruiser coils & Tundra Tokico shocks, 5/8" trim packers(Set up for heavy load - rear sits high when empty)
-custom coil retainers
-Sonoran steel adjustable pan hard bar (bushings recently replaced), extended bump stops, sway bar bracket, front diff drop
-Sonoran steel indestructible rear lower links
-rear upper links replaced
-all front control arm bushings replaced (lowers 2021)
-tie rod ends, upper and lower ball joints replaced w OEM
- rear sway bar links replaced - 2021
*ARMOR*
-TJM front winch bumper modified w light bar hoop & welded wings.
-IRBIS rear bumper & swing away tire carrier, shovel mount, dual 20L NATO jerry can mount (removable)
-Budbuilt skid plate
-Stubbs sliders
*Exterior add-ons*
-BFG AT KO2 235/85/16 , approx 5000 miles
-4Runner Limited rims (x5)
-ARB air lockers front & rear
-ARB compressor installed + air line Q/D for tools etc.
-4.88 gears F&R installed and set up by Zuk (http://gearinstalls.com/)
-Front diff rebuilt all new OEM bearings & seals
-Custom lo-rise snorkel & Top Spin particulate separator
-Extended axle breathers
-Updated air box and MAF sensor from 1999 4r
-battery X2 Power AGM 27f, 930 CCA ($350) new in 2020
-Yakima roof rack bars & towers
-HAM antenna
-12” LED light bar
-Warn M8000 winch and Albright Contactor (not included)
*interior*
-Yaesu HAM radio w remote head unit & speaker
-Ram Mount ball (only)
-Kenwood cd/radio/mp3 deck w Sirius receiver
-Polk speakers
-Blue Sea dual USB port
-ARB compressor switch
-ARB front & rear locker switch
-additional hidden USB charger port under dash
-Rear cargo area power panel - Cig light port & Engle Fridge plug port
-LED light strips (x2) on rear gate
-rear seats removed, custom flat floor storage deck installed, easy 2 bolt removal if desired.
— rear seats & headrests are included, in like-new condition, have been removed for last 10 years
*OTHER MAINTENANCE*
-Mobil 1 synthetic oil since 2002
-steering rack replaced
-2nd timing belt replacement completed (also water pump, thermostat & idler bearing)
-Front brembo rotors, OEM pads
-Rear brakes recent
-Starter replaced (Napa lifetime warranty)
-OEM Toyota CV’s rebuilt w OEM Toyota boot kits, two brand new replacements CV’s included
-All front ball joints & tie rod ends replaced with Toyota OEM
-All wheel bearings & seals replaced OEM Toyota
*Known Issues*
-windshield cracked - will replace before selling.
Westy
I've spent hundreds of days out in the field with this truck. Its every bit as described. Super solid, simple, capable, reliable and a great all around vehicle.
This vehicle will be missed but surely the new owner will experience many great travels and experiences.
McKinstry
If the sale falls through I'd be very interested in purchasing. I have a 94 Toyota Pickup and am looking for a 4runner so I can carry more people. Sweet vehicle!
