Tbars
Local pick up prefered but can deliver between the OC and Indio tomorrow only during the early mid part of the day..
..Here's a link to the info on it..
http://www.coleman.com/product/perfectflow-2-burner-propane-stove/2000007502#.UzM_68768zk
This is barely used in great shape, a fantastic camping 2 burner stove and it uses the little green bottles of propane that you get at Walmart for like 2 for $5.
I am including 1 pretty full bottle of propane and 2 long neck lighters to go with it. One lighter even has a flexible neck.
all of this is included for $30 call or text 714-758-5091
Cook breakfast, lunch and dinner on a stove that folds up easily with the Coleman® PerfectFlow™ 2-Burner Stove. The large cooking surface gives you space to prepare different dishes. Once this propane-powered camp cooker starts to heat up, PerfectHeat™ Technology gets the temperatures just right, WindBlock™ Shields keep the wind from blowing the flames around and the PerfectFlow™ Pressure-Control System keeps the heat steady on each of the high-performance 10,000-BTU burners. When you're done, the removable rust-resistant, aluminum-steel cook top makes cleaning quick and easy.
PerfectFlow™ pressure-control system
PerfectHeat™ Technology for burner efficiency and optimal product life
WindBlock™ wind shielding system for maximum heat
Two 10,000 BTU burners
Rust resistant aluminum-steel cook top
Enough stovetop space for a large pan or griddle
Boils a quart of water in 4.5 minutes
Works from bulk cylinder with accessory hose (not included)
1 cylinder of Coleman® propane powers both burners for 1.1 hours on high, 4.5 hours on low
Closed measurements 14.75 in. x 23.25 in. x 5.5 in. (37.47 cm x 59.06 cm x 13.97
