[SOLD]: Eberspacher (Espar) Airtronic S2 D2L [Updated model] - $900 shipped
jdzl
Bought this for our Delica project. Sold the Delica, so no longer need this! Have installed a few of the D2 models and only complaint was the clicking fuel pump (which really wasn't that bad) and the fact that you had to pay extra for altitude compensation harness/sensor. New model (this one) fixes both those problems.
This includes pretty much everything you need to install, save for a plastic tee for depending on what size fuel line you are teeing into.
Extras
- EasyStart PRO 7 Day Timer controller which is pretty slick.
- 8x5x8 tee / clamps
- Z bracket for mounting exhaust "muffler"
- Round floor mount bracket which is upgrade over the flat plate mount
New in box, looking to get $900 shipped to lower 48.
Benefits of the new Airtronic S2
Stepless heating performance control.
This allows for a more dynamic heat output, that automatically modulates to maintain required temperature. The new “Stepless output control” has also improved the operating sound of the Airtronic S2
Noise emissions optimised.
The new AS2 Kit also includes the new, almost silent, Eberspacher digital fuel dosing pump with mechanical damping ring and intelligent current control.
Automatic Altitude Adjustment
Altitude adjustment will be automatically handled by the Eberspacher Airtronic 2 up to 3000m above sea level; no additional altitude kit is required, the AS2 has an integrated altitude sensor.
OBD On-board diagnostics with the EasyStart PRO.
Fault display via the Easy Start PRO. The Airtronic S2 coupled with an Easy Start PRO will give a text-based fault description, reducing confusion and saving time diagnosing the issue.
dhuss
