SOLD.....FOR SALE: 2017 Horizon Off-Road Trailer by Adventure Trailer (AT Overland)
tenebs
I purchased the trailer in November 2017. This is an awesome off-road trailer. It tracks well and you don’t even notice it is behind you. This is a great set up and very functional and convenient. Various life circumstances have made it difficult to get out and camp with it as often as I had hoped based on previous camping trip history in our lives and I need to reconfigure my camping setup to accommodate these changes.
I extensively documented my trailer build and customization with lots of photos on my website:
https://www.margygreen.com/Blog-Adventure/Trailer-Horizon
Excellent Condition: This trailer has been used on only on 5 camping trips (4 in Arizona (21 nights) and 1 longer trip to California (7 nights) and the drive home from Adventure trailer for a total of only ~3600 miles. With the exception of trips and when I was stocking, cleaning or modifying it on my driveway, it was always been stored in the garage. Downsizing for simple minimalist 1 night only trips that will fit into schedules better.
Trailer & Chassis Info:
Powder coat steel, white boxes and black chassis, with aluminum thread plate steps & fenders
Main Cargo Box (40”W x 30”H x 54” L)
Rubber mat floor with interior tie downs
Custom two drawer Highway Products All Aluminum full extension drawers: Interior drawer dimensions (LxWxH): Bottom 50-1/2 x 12-1/4 x 8-3/16, Top 29-7/8 x 14-1/2 x 10-7/8
I used the top drawer for food and includes three removable plastic bins that perfectly fill the space. The bottom was used for gear. Top drawer short in length to allow storage of items in box via lid access.
Customized Tembo Tusk pull out fridge slide with 17x28 max fridge size. Slide is longer length to clear door frame for opening lid clearance.
Setup for National Luna Twin with DC and AC outlet. AC direct to AC shore power to allow quicker cool down times before a trip
Tembo Tusk fridge slide cutting board addon mounted under fridge slide. Never used as a cutting surface
National Luna Weekender, 50L Fridge/ Freezer, Split, Stainless Steel, (26.5L x 15W x 20H), includes interior bins, 4 tie downs
This is an awesome two compartment fridge with a 40L fridge and a 10L compartment that is ~10C below the main compartment that can keep items frozen, including ice cream or popsicles. The only reason I am selling is I have a second fridge already.
Custom rear fridge barrier to maintain air space and prevent gear from falling into fridge area when it is pulled out
Side Boxes: 2 side cargo boxes with drop down doors (carpeted) (14″W x 14″H x 54″L)
Passenger Side - Kitchen side door with custom cutting board (never used for cutting), Including supply bin and current organizer (both removable)
Drivers Side - used for clothing and toiletries (includes removable toiletries storage box)
Both sides have removable carpet with an extra piece for either side
Nose Box ((32″ W + 12″W) x 20.5″ H x 21.375″L)
19 Gallon roto-mold water tank with 3"' opening, 1/2" drain plug and manual pump, Add-on under tank valve and removable spigot
Exterior stainless-steel sink: removable with drain hose and plug & mount
2 AT Overland locking and tamper resistant can holders with three straps: 2 NATO & 1 Sceptre (so you can carry 1 gas 1 water or 2 fuel)
Metal NATO 20L gas can and spout & Tan Sceptre 20L water can
Suspension & Chassis
black powder coat steel chassis with front & rear boulder bars
Independent Trailing Arm Air Suspension (TAAS) V.4 with air springs (air ports easily accessible on tongue) and adjustable shocks
Electric Braked Axle Upgrade with 10"' drums, includes break-away kit
2" rear accessory receiver with removable shackle receiver
3 bar roof rack and L-track rails with adjustable track tie down rings
AT Overland Swing Away Tire Carrier
MAX Coupler and Curt 45110 Class 3 8" rise for vehicle
2 level gauges front and passenger side of main box
3 keyed alike Master Lock hitch pins: (rear receiver, 2 for max coupler: trailer & vehicle side)
5 keyed alike American Lock padlocks: 1@ nose box, 2@ top lid of main compartment, and 2@jerry can and water can mounts
AT Overland Bulldog solid wheel jack used when parked long term to avoid wheel compression
AT Overland customized Bulldog pneumatic rubber wheel jack used when on trips
Trailer Valet 5x- used to move trailer around easily in garage and on driveway
This trailer is very stable and does not require the use of rear stabilizers.
Overall length 124", Overall width 68", Base Weight: 1100 lbs before accessorizing
Tires & Rims
2" Wheel spacers
3 Tires: BF Goodrich All Terrain KO2 p265/70R17 load C rating (Only 3600 miles, spare never used)
3 Rims & lug nuts & 2 center caps: Toyota Factory Match Alloy wheel; 17x7.5; 5 spokes; 6 lug; 5.5"" BP"
Propane Tanks & Mounts
2 Manchester 11lb 12.2" dia propane tank with 2 propane tank tires
2 customized 4B's Bracket TH112 tank holders
Awning
Alu-Cab Shadow Awning - Right Hand Passenger Side. It is so quick and easy to deploy and put away and is my favorite awning.
Expedition Outfitters Folding Stainless Steel Awning Bracket: Designed for Horizon Trailer and Alu-cab awning (or other 270-degree awnings). This allows the awning to be folded over the tent when driving.
Custom gray 87% shade panels: 1 large panel 12 ft by 12 ft can be extended with poles to extend shaded roof, 2 small panels 12 ft x 7 ft and 12 ft x 5 ft. Adjustable and attach to awning in any position along the edge
Small brackets on the top exterior of the awning mount to hold the tents rainfly rods Allows the tent rainfly to extend over the awning
Electrical
In Nose Box
2@ Valve Regulated AGM group 31 deep cycle battery 105 AmpHr
13L x 6.75W x 9.38H 69lbs each
Wired in parallel to provide12V @ 210 Ah capacity
Powder Coated Battery Tray, 4ga cables, & hold downs for 2 batteries
Shore Power & Battery Charger
NOCO Genius Gen2 20 Amp 2-Bank Charger
NOCO Genius GCP1 External Weatherproof AC Port
Blue Sea Systems 12 Circuit w/ negative bus fuse box
All wires and fuses labeled
12V Ports
12V exterior voltage display (passenger side nose box)
Exterior DC port (passenger side nose box)
2 ports @2.1A each USB port in each side box
Wiring for fridge (12V & AC) nose box to main box
Wiring for lighting and USB/12V ports, boxes, etc.
Solar Controls in Nose Box
Morningstar SunSaver Trakstar MPPT Solar Controller
15amp 12V or 24V
Morningstar remote temperature sensor
SAE Exterior Solar Port for plugging in optional external solar panel.
When camping I plug in a larger rollable flexible P3 Solar 200W 24V panel for charging batteries with fridge load (Not for sale with trailer)
Ganz Eco Energy 12W Marine Grade Solar Panel mounted to nose box lid to trickle charge batteries, brakes, etc
Sea View Cable Gland for nose box solar panel
Lighting
Nose, Main, Kitchen, & Driver's Side Box:
Waterproof SMD 5050 LED Warm White light with safety flip cover toggle switch
Aluminum 45 degrees LED mount with diffusers
(2 port @2.1 Amp USB charger ports also in both side boxes)
Switch Panel Box:
safety flip cover toggle switched for:
Box light, awning light, exterior sink light, & USB ports
Exterior Sink Light:
Rigid Industries 48001 A-Series Warm white LED light with angle mounting kit
Awning:
Waterproof SMD waterproof 5050 LED amber light on each awning arm with safety flip cover toggle switch in kitchen side box
Exterior weather proof plug to connect awning lights and connector cable
Eezi-Awn Globe Tracker Trailer Tent
Closed 83" Long x 59" Wide
Ground Level Room 83" L x 93" wide includes Eezi-Awn ground mat and storage bag for room if removed from tent.
Mattress 79" x 63" x 3.5” thick w/ Pure Green 1" latex mattress topper
The tent, room walls, and bedding all fold up and fit under the cover.
I purchased extra tent rain fly poles to cut 4 down and customize them to fit into mounts I installed on top of the Alu-Cab awning allowing the tents rain fly to extend over the awning.
The tent is fully functional and waterproof. The top of the cover has cosmetic grayish marks from an Aluminum table I carried on top and the fold over awning. The cover back rear has a small repaired cut. One of the awning room windows mesh had a 2” tear which has been sewn. Some of the plastic buckles have been replaced.
The tent is clean with no odors or mildew, after every trip the tent gets aired out and cleaned.
This is a great comfortable tent. The room has provided shelter in the cold and a windy rain during monsoon season. The trailer side wall panel for the room has a zippered opening that you can open to allow access to the driver’s side box. It is such a convenience to be able to stand and change clothes with your own dresser box.
Additional Items
Blue Ridge Overland Tire bag for trash mounted to side of tire
Yakima Spare Tire 2 Bike carrier with built in lock
4 rubber wheel chocks
Custom Birch removable side shelf for kitchen side nose box with storage bag, Custom nose box removable shelf
Polder 2-Step mini stool
Sale & Contact Info:
In Arizona this trailer is registered with a permanent tag. Clean title in hand with no liens.
Price as originally Built: $31k+ This does not include labor and additional fees and many smaller but needed parts and accessories.
Pricing this configuration out with current pricing would be well over $35k
For Sale For: $ 26,000
If interested please contact me via expedition portal or text only (520.954.0898). Due to my job I usually do not have access to the internet or phone during work. I will respond as soon as I can.
Goldenbora
