SOLD: Four Wheel Camper Fleet Front Dinette - Bay Area, CA
fwctaco
SOLD - Thanks
2015 Four Wheel Camper Fleet Front Dinette
This camper has been fully optimized for off-grid use and is 100% ready for adventure.
Asking $17,000
Standard Options:
  • White aluminum exterior
  • Roof vent with fantastic fan over living area, extra roof vent over bed
  • Standard sink/stove combo
  • Dark blue cushion fabric
  • Standard propane heater
  • 4 Reico Mechanical Jacks with 2 manual cranks and 1 drill attachment
  • 2nd/3rd Gen Tacoma mounting brackets and custom rubber bed mats included
  • Standard factory aluminum turnbuckles included
  • Buyer will need to either have a wiring harness professionally installed or DIY to connect the camper to truck battery
Modifications:
  • Upgraded Electrical System:
    • 200AH LifeBlue Lithium Ion (LiFEPO4) Battery
      • Approx 4x the capacity of the factory AGM battery, lighter weight, and 4x lifespan. This battery will likely last longer than the camper.
      • Includes Bluetooth battery monitor
    • 200W of low-profile, roof-mounted solar panels
      • Premium Lensun flexible aluminum panels glued to roof
      • Additional portable panel may be added using the factory connector on the back of the camper
    • 1000W Xantrex Freedom XC Inverter/Charger
      • Run 120V AC appliances up to 1000W off of the battery
      • Efficient 50A battery charging from shore power
    • Sterling Power BB1230 Smart Battery to Battery Charger
      • Efficient, safe, 4-stage charging from vehicle alternator
      • Customizable automatic relay connects/disconnects alternator from camper battery
  • Replaced factory 3-way fridge with Isotherm Cruise 65 12V DC Fridge
    • Fridge includes 120V AC controller, but it isn’t hooked up to power
  • Removed factory cassette toilet
    • Space inside camper where toilet was is now open storage
      • See pictures for an example of how we used this space
    • External toilet service hatches were sealed with high quality, white aluminum panels, interior holes were left as they were
  • Water system optimized for off-grid/winter use
    • Added small, optional ½ gallon interior greywater system
      • Greywater can be routed either inside to a ½ gallon tank under the sink or to the standard ⅝” fitting outside. Interior tank is small, but useful for cold winter camping or situations where draining your grey water outside is not acceptable.
    • City water hookup has been disconnected, but can be re-connected if desired.
    • Shurflo Everpure inline “under sink” water filter
      • Water in 20 gallon tank is pre-treated using bleach and the everpure filter removes particulates and bleach. This keeps the tank clean and your drinking water safe.
      • Flow rate of faucet is unaffected.
  • Storage Mods
    • Storage under passenger dinette seat has been converted to a lockbox with hinged door and key lock.
    • Bamboo storage box on countertop
    • 2 wall-mounted Tackle Webs mesh marine storage bags
  • Custom sewn thermal pack
  • Overhead lights converted to low wattage soft white LEDs
  • WeBoost 4G-M Cell Phone Booster with window mounted antenna
  • Indoor Temperature and Humidity Gauge, Outdoor Temperature Gauge
  • Lux GEO-WH Smart Thermostat
    • Turn heat on from the truck cab using WiFi (WiFi hotspot or other device needed)
    • Program heat to come on before your alarm in the morning
  • AT Overland Aluminum Jerry Can Holder and Jack Bracket with Red NATO can and non-carb spout
  • Screen Door screen replaced with No-See-Um Netting
  • Screen door cross bar added on screen door
Extras
  • 2 10lb propane tanks
  • 25ft Teknor Apex Zero-G ½” fresh-water hose
  • 8ft Grey water drain hose
  • 50ft 14/3 Cold Weather Extension Cord with Lighted End
  • On Stage Speaker stand that can be used to raise/lower the roof with a drill
  • Portable waterproof garbage can, hangable by strap and buckle or velcro
  • Delxo 2-step steel fold flat step ladder
  • 2 No-See-Um Screen Covers for rear turnbuckle doors
  • 2 2x USB charging inserts for the factory 12V “cigarette lighter” receptacles
  • 4 custom made 60lb lift struts - never installed, but planned to use them if I put a roof rack and box on top
Minor Issues
  • Very small tear in the corner of the interior ceiling liner. It was like this when I got it. Someone left something on the counter when they lowered the roof. I would not notice this if I wasn’t looking for it specifically.
  • Bubbling in vinyl floor near the door. Vinyl floor has started to separate in a couple small spots near the door. The edges are still fine, there are just a couple small spots you can feel in the middle of the floor.
  • Some “oil-canning” on the roof, which seems to be common with these newer seamless roofs
  • One of the interior ceiling trim pieces has a small abrasion in the outer layer and will swell/shrink with high/low humidity. It was like this when I got it. Pretty much a non-issue, and could be fixed with a new trim piece or sealing the abrasion.
Goldenbora
