SOLD - Heavy Duty Cargo Slide - San Diego
THATSALEXUS?
I have two unused System Edstrom http://www.systemedstrom.com/uscargo slides that I would think would be pretty useful in an expedition vehicle or trailer. These are designed for use in commercial vans, but I think they would be great for an off-road trailer, SUV cargo build out, etc. The specs are: 28.5" wide by 38" long (closed), 61 1/4" long (open) and are rated at 440 lbs. conservatively. The actual slide mechanism is sealed ball bearings. Dealer cost on these is a little over $300 each but I'll let them go for $150 each.
I'd prefer local pick up, but if you'd like, you can get a shipping quote from UPS.com just enter the dimensions: 30"x39"x4", 50 lbs. from 92071 commercial address. If interested, please e-mail me at stevef66atgmaildotcom.
Here are some pics including a couple in my 4Runner for size perspective:
jeep-N-montero
Man, I was all excited and was about to ask for your paypal address until I went out and measured, the slide is about 1.25 inches too long to work. BTW, USPS is the cheapest as far as shipping options in case anyone is comparing.
MANUCHAO
Aventurero
what is the weight on these ?
The measurements you provided are they exact ?
Any mo pics of the bearings mechanism and how they slide ?
I might be interested.. here in SurCal as well...
THATSALEXUS?
The measurements are pretty close to exact. I just measured again and this is what I came up with:
H - 2 7/8"
W - 28 1/2"
L - 61" (open)
L - 37 7/8" (closed)
Weight - 45 pounds with my bathroom scale
The bearings are inside the tracks, so there isn't much to see. These are set up the same way that virtually every heavy duty slide is set up, with 4 sealed bearings, 2 at the front of the base and 2 at the rear of the slide.
Mo Betta
It will fit in my 4runner but the height puts the outboard motor too high for what I need. Sorry it wont work for me.
Mo Betta
I was going to use it a cargo slide, but the total build height plus my 20Hp 4 stroke outboard with our gear on top, puts it above the cargo cover. The OB has to lay across the back in the widest part of the storage area, just to fit.
