!! SOLD !! High Quality On & Off-Road So-Cal Teardrop 510 XS in Excellent Condition
2006pct
With over $38,000 invested, this low-mileage trailer was built with high-quality materials and robust construction by the founders and original creators of So-Cal Teardrops in Southern California. Known for its exceptional durability and comfort, this 2017 So-Cal Teardrop 510 XS makes a perfect companion for any trip — handling the toughest terrains and providing a cozy, well-designed interior for a comfortable stay. Whether you're navigating rugged backcountry roads and boondocking or spending time in an established campground, this massively upgraded trailer is designed to go wherever you want — although it has never been off-road.
Easily Towable: with an overall length of 12’ 7”, width: 6’ 8”, height: 5’ 5”, and weight: approximately 1200 lbs. Interior: length is 9’ 2”, width: 4’ 10”, and height is 4’. These dimensions make the 510 XS a spacious and practical option for a compact trailer, offering ample room for comfortable sleeping and storage while being easy to tow with most vehicles.
High Quality Materials: The 510 XS features a 2x3" steel tubing frame with .120 wall thickness, heavy-duty Old Man Emu leaf springs, 10-inch electric brakes, and 9-way adjustable Rancho RS9000XL shocks, making it well-suited for both on and off-road conditions. This trailer comes with a set of low mileage Cooper Discover ST Max (255/85R16) tires with a full-size spare in a Toyota (6 X 5.5) pattern. Constructed with a reinforced rib system, this teardrop easily handles the stresses of off-road travel.
Comfort & Versatility: Inside, it offers a comfortable queen mattress that is 4 inches thick, premium exterior and interior LED lights, multiple 12V outlets and USB ports, and various marine-grade storage cubbies and shelves.
Significantly Upgraded Electrical System: The electrical system was fully upgraded last year with Bluetooth monitoring using the Victron Connect App that is accessed via a smartphone. Components include:
  • Two (2) 100 amph, BattleBorn 12volt Lithium batteries with - less than 100 cycles on each that are all connected through:
  • Victron: Lynx distribution system with BlueSea system master cut off switch with each circuit additionally protected with BlueSea system thermal circuit breakers
  • Victron Phoenix 375 watt pure sine wave inverter
  • Victron Blue Smart, 30amp charger/power source
  • Victron MPPT Smart solar charger 150vt, 35amp; suitable for up to 500 watts of solar
  • Victron Orion Smart 12/12 – 30amp, DC/DC charger
  • Victron Smart Shunt 500amp
  • Custom Aluminum Battery Tray(s)
Additional customizations and upgrades on this particular trailer further enhance the balance between comfort and durability and make it a great option for those looking to explore remote areas while still enjoying the conveniences of home.
External Features & Upgrades
  • Pneumatic front jack wheel
  • Multi-axis "Max" Coupler for increased articulation and off-road capability
  • Expanded metal cage w/ locking lid
  • Front storage box - steel (granite coat)
  • Three (3) stabilizer and leveling jacks (will also allow for tire changing); One (1) wheel jack
  • Roof basket
  • Tube fenders
  • Side mounted LED "porch" lights
  • LED ground lights
  • Two (2) exterior mounted 10 lb. LP tanks
  • 30 gallon water tank w/ electric pump (twin 15 gallon tanks with crossover valve)
  • Instant water heater and outside shower hose mounted in lockable aluminum box
  • Awning / room configuration with three (3) Scipio Annex walls, two (2) with built in windows
Internal Features & Upgrades
  • 14x14" Fan-Tastic vent/fan
  • Secured, locking mechanical safe
  • Premium interior LED light fixtures including white/red interior dome light
  • Two (2) bedside gooseneck system reading Lights
  • Two (2) flip down, bedside shelves
  • Marine interior cabinetry including doors and latches
  • Under-mattress storage box
  • Thermostatically controlled Propex propane furnace
Kitchen Features & Upgrades
  • Galley-mounted bar fixture
  • Two (2) additional kitchen storage drawers
  • ARB 50qt refrigerator on an aluminum tray with locking slide
  • Slide out Cook Partner 2 burner stove
Asking Price: $19,500
  • For Sale - So-Cal 510 XS Teardrop Trailer.pdf
2006pct
Here are a few more photos, including photos underneath the trailer showing that there is no rust at all. In addition, there is a locking, multiple fishing rod holder mounted underneath the trailer that we did not mention in our original post.
tenacstud
Can you tell me the length of the sleeping area, head to toe? Want to make sure my 6'1 wife and I can sleep comfortably.
2006pct
Thanks for your question and interest, @tenacstud. The bed is 88”L x 59”W with a 4” mattress. I am 6’2”, and my wife is 5’4”, and we fit in the bed quite comfortably.
Let me know if you need any more information.
2006pct
PRICE REDUCED TO $15,500.
We are going to be traveling internationally for a while, and it doesn’t make sense to pay for storage for the time we are gone. We have dropped the asking price from $19,500 to $15,500.
drpepper
Hi! If this is still available, I was wondering if you're including the vehicle side max coupler? And I'm assuming it's a 7 pin connection to the vehicle (i.e. needing a trailer brake controller)?
Also, I would want to put a RTT on it (family of 4). I'm not sure what kind of crossbars are compatible or how the roof basket is mounted, but any thoughts you might have on that would be appreciated. Thanks!
2006pct
@drpepper, yes the trailer is still available. Yes, we are including the vehicle side of the max coupler which is mounted to a standard 2 inch slide in the receiver. The drop needed is vehicle dependent, and I will include the one that works on my Tundra. And yes, it is a 7 pin connector; so, a controller is needed. I easily mounted one in my Tacoma and with the Tundra, it was factory installed. While the trailer is very light, having electric brakes is simply a nice feature.
The roof basket/rack is certainly stout enough and could readily handle a RTT. I am not specifically familiar with the different mounting options and am speculating they are somewhat brand dependent. I noted multiple photos for RTT’s on teardrop trailers when I did a google images search, and it showed a number of options. I have seen a few on the road and a few set up in camp, but beyond that, I don’t have much experience or help to add when it comes to RTTs. One thing to note is the Fan-Tastic fan in the roof of the trailer. The rack is above it, but fully opening the fan hatch/lid would likely be a bit restricted if a RTT was mounted flush to the rails (likely). It will still work, but that’s something to be aware of.
Hope that is helpful. We are leaving the country in a few weeks for an extended period of time; so, let us know if you interested.
2006pct
@drpepper , DM’d you this morning.
2006pct
Our international travels are going to start in a couple of weeks. We will be able to entertain offers for the next week or so before we go. The original asking price dropped from $19,500 to $15,500. This is a great deal on a great trailer.
