Jolly Roger
***SOLD*** This was purchased for a motorcycle trip up to Alaska. It's been used about three times, two of those were in my garden before we left to test it. The unit is pretty much in mint shape and comes in the original box with all of the accessories. The only thing missing is the USB charger which is somewhere in my house but which I can't find at the moment. However, I will include an upgraded USB charger which has multiple concoctors so you can charge the phone and other devices (iPod, etc.) at the same time. As and when I come across the original wall charger I'll send that along to whoever buys the phone.
The few times I used the phone it worked great and I had no issues whatsoever with it. The one time I called on my trip was from Inuvik in the Northwest Territories, which is as far north as you can go by road in Canada. The reception was great and the phone is very robust. Here is a link to the site.
http://www.isatphonelive.com/product
$425 US shipped in CON USA or Canada. Payment via PayPal using gift option or add 3% to cover PayPal fees.
Features
- satellite telephony, voicemail, text and email messaging, GPS location data
- battery life up to 8 hours talk time and up to 100 hours standby time
- operates at -20°C to +55°C; dust, splash and shock resistant (IP54); humidity tolerance from 0 to 95 per cent
- supports Bluetooth, place the handset on its side, with full manoeuvrability of the antenna, for easy handsfree use
- easy to use intuitive GSM-style interface; high-visibility colour screen; larger keypad for easy dialling with gloves on
- reliable network connection operates over global geostationary satellites that will be operational into the 2020s; significantly less possibility of call dropping
Specifications
Length: 170mm
Width: 54mm
Depth: 39mm
Weight 279g - including battery
Display High visibility colour screen
Interfaces Micro USB, Audio socket, Antenna port, Bluetooth 2.0
Water and dust ingress protection IP54
Operating range -20°C to +55°C
Storage range -20°C to +70°C (with battery)
Charging range 0°C to 45°C
Humidity tolerance 0 to 95 per cent
Features
Specifications
Length: 170mm
Width: 54mm
Depth: 39mm
