SOLD: James Baroud Space EVO hardshell RTT - Portland OR
dabbinuguay
James Baroud Space EVO hardshell RTT in good condition.
Outer dimensions 80" x 56". Weighs about 135 lbs. Has original foam mattress, plus additional 1" foam topper, and still holds all bedding. 2 sleeping bags, 2 pillows, 1 flannel sheet, 1 wool blanket. Cozy at 9deg F.
Solar fan works fine.
Asking $2100.
dabbinuguay
Howdy - Just the normal questions. How old, what kind of condition and usage, why are you wanting to sell? Thanks!
I'm the second owner. I purchased the tent last summer and was led to believe the first owner hadn't used it much at all. I'm guessing it's a couple years old.
I chose this tent due to it's quality, light weight, and ability to hold significant amount of bedding for 2 people.
Selling as I'm replacing the canopy / shell combo with a SuperPacific wedge setup, mainly because I need to be able to use a roof rack regularly with heavy loads, and I don't want to be constantly installing and removing a tent to do so.
As far as condition goes, I think it's good. There is a very small amount of rust on the outer part of the wire clasp of the latches. All zippers are fine, no issues.
I'm updating the original post in a moment with more pictures.
Please let me know if I can answer any more questions.
dabbinuguay
Additional pictures
There is a bit of rust on the lower part of clasps.
Mounting hardware will accommodate a crossbars up to 1 3/4" wide.
Clemtiger84
