Sold - Land Cruiser 1990 Toyota HDJ 81
Alphias Dodge
Toyota HDJ81, Land Cruiser, 1990, VX, 5 speed turbo diesel. $35,000 (no trades, price firm).
Purchased from Montana based importer. Selling it ‘because I have two, almost identical JDM 81 series cruisers and am keeping the one with double dif locks for my steep Montana driveway. Images
It is currently (1/2021) at TorFab (Seattle) for a thorough, pre-listing inspection. Because it’s in Seattle, there are some details of the work that I cannot verify with access to the vehicle. This is a great opportunity for a Seattle area buyer to get a wonderful 80 series diesel and using TorFab for a pre-purchase inspection.
Here’s the long list of work done.
Engine:
Mileage reads 213, 405 kilometers- as far as I know, that is correct.
Turbo rebuilt, with boost and pyrometer gauges; HPD top-mount intercooler
HPD Catch Can
Injector rebuild
New Interstate batteries
Block Heater
Compression test, results available
New OEM alternator.
1HDT engine major service kit
Electrical charge system inspection & test
Ac idle up controller removed
Possible new OEM radiator
Drivetrain, suspension, etc.
Transmission rebuild w/Terrain Tamer clutch.
OME heavy suspension kit
Front Axle wheel berring & spindle kits, Delta rear panhard bracket & front radius arms
Interior
Front & rear window rebuild with new regulators, etc.
Kenwood Excelon audio unit.
New steering wheel
Rear seats removed but available.
Driver’s seat cushion replaced
Rear hatch struts.
Misc.
Probably original paint.
Hood & scoop wrapped as flat black.
Redarc Tow-Pro Elite Trailer Brake Controller & 7 pin rear bumper plug
Custom Trekbox (s)
Ac recharge
New front seat belts
Terrain Tamer Brakes and rotor rebuild. OEM caliper.
Rust check, small spots: rear side window, around bottom, rear door bottom.
Custom rear tire carrier with fold down table
Fuel tank removed and checked for corrosion,
Delta front bumper
Warn ZEON Platinum 10-S - 10,000 lbs. w/ Synthetic Rope
Front Runner rack with Easy out Awning, shovel holder, Roto Pack mount
BFG KO-2 Tires.
new headlights (maybe LED’s)
Goldenbora
