SOLD. Off-road trailer with fold-out tent, awning, and annex / sun room
Inukshuk
Guide
EDIT: SOLD, thank you all for interest.
Bear Trailersports Trailgater overlanding and off-road trailer (2012) with Kakadu Bushranger 250 tent with awning and annex / sun room
EDIT:
Denver, Colorado
  • What I have done:
  • New tires and wheels (the LC70 series rims are staying with me. I have a great use for them.)
  • Tongue crack welded at critical junction to cross braces. TIG welded by certified welder.
  • Battery charged and held charge for months (this may be old, but electrolyte was full and holds a charge)
  • Water tank works
  • Cover zipper restitched to cover. Thread had failed, the rest is good.
  • New 7 way blade connector
  • Title in hand
  • What could be next: Awesome slide out kitchen at tailgate. It would be under the side room cover
The Trailer Base:
  • Bear Trailersports Trailgater trailer with all upgrades available
  • MFG price as optioned in 2012 was $5,465 (www.beartrailersports.com/wp-content/uploads/2019/04/Trailgator-order-form-2012.pdf).
  • 2021 Trailgater II similarly spec’s is now $8,250 (www.beartrailersports.com/off-road-trailers)
  • 3500 lb Dexter adjustable spine torsion axle. Currently about 20 degrees (estimated) upward torsion axle setup (about 2-3 inches) so I estimate you could lift 4-6 inches just by adjusting the splines. See for example www.tiedown.com/pdf/c1413.pdf
  • Goodyear Wrangler Kevlar, 265/70R16, like new tread depth, DOT Codes 4317 and 0119 (October 2017 and December 2018) on Tacoma black steel rims (these were Tacoma factory spare tires)
  • bolt pattern 6 on 5.5 (LC80, Tacoma, Tundra, etc) (can fit taller tires
  • Electric brakes
  • Max Coupler 360 degree articulating hitch (not the oldest style, not the newest style with wing)
  • Lockable tongue storage box with, trapezoid shape made to fit tongue, Chrome T-handle (replacement key on order)
  • Interstate 12V battery (this may be old, but electrolyte was full and holds a charge)
  • Toyota spare tire hanger under bed & in front of the axle
  • Tailgate
  • Step fenders
  • 2” rear receiver
  • 4 D ring recovery points
  • 23 gallon water tank mounted above axle with RV pump and hose spigot
  • 4 x 48 inch L-track/airplane tracks with 1 inch rings to secure load
  • Adventure Trailers 5lb propane cylinder bracket
  • 5lb propane tank (if you want it)
  • Box size, 84” x 52”
  • Box sidewall height (approximately 13 7/8”
  • Box lid flips up (with tent on it) to access trailer box
  • overall trailer height 41”-42” to accommodate tent section (keep this in mind if you are thinking to lift it)
  • trailer tongue apparently lengthened by previous owner
The Bushranger Tent and Annex/Sunroom:
  • The 250 is the largest tent section offered, great for a family or extra people. The inside of the tent has dividers to separate sleeping areas. Build quality reminds me of my OZ Tent
  • Thick queen newer foam mattress
  • can access trailer box from under mattress while tent is setup
  • comes with
  • Sunroom roof - doubles covered area
  • Sunroom wall (new in bag)
  • Sunroom PVC Floor (new in bag)
  • Extra older cover
  • Foam floor squares
  • tent can be removed and trailer may be used as a utility trailer
  • www.xpedbc.com/kakadu-bushranger
This same trailer before
Price: $5,928.00. Reduced 9/5 to $4,999.00 OBO
Inukshuk
Guide
I will be camping in this at Overland Expo Mountain West and I'll have the title with me. I should be set up near the Yamaha semis. ask me about the show discount ?
iStan814
