SOLD - OME Rear Coil Springs: Mitsubishi Montero/Pajero GEN II
Marcus2113
Listed is a set of Old Man EMU (OME) used (approximately 2 years of use) Rear Coil Springs for the 1991-99, Long Wheel Base Mitsubishi Montero.
Cost: $60, plus shipping (depending upon location)
tyty13
Hi can you see what would be the shipping to 92807? Also do you know if the springs an MD or H?
thanks
Marcus2113
Good Evening, The springs are Medium Duty. I will get you a quote by this weekend. The current location is GA (I meant to include that in the ad).
jeep-N-montero
Doesn't appear the tags are still on them, did you by chance mark which was the left and right side spring? I ask because it matters when you install them and will save someone from having to do the work twice if not correct the first time.
Marcus2113
SOLD
But to your point, these springs never had a tag or distinguished between a left or right spring. Based on the seat for the coil, I made an educated guess at which would be the left and right, but honestly I never heard of these springs having tags. I ordered numerous custom coil springs from Spring Works (more than one Montero) without any differentiation either.
