SOLD - Overland 2017 GMC Sierra 1500 SLT 4x4
Apache32B
FOR SALE: Overland Black 2017 GMC Sierra 1500 SLT 4x4
Location
: Temecula, California, USA
Description: Fully built out Sierra 1500 SLT 5.3L 4x4 with a huge list of modifications. The truck crushes it on the trail, in the snow, and overall for a huge amount of fun with family and friends on the trail. Has always been maintained, with zero accidents - clean title. Currently, the milage is 81,450. Check out some of the work done to it below and help this find a new home.
  • BlackBear Performance Full AutoCal Tune with Flex delete and will sell the programmer. Engine and Transmission is tuned with all upgrades on the truck. This truck hauls ass if you want to get on it.
  • Fox Racing 2.0 Front & Rear Performance Series Coil-over IFP / Shocks: Upper mount includes a composite bushing that isolates noise and vibration. Locking, spring preload rings that allow easy ride height and preload adjustment.
  • Method 308 Grid Matte Black Wheels: The 309 Grid Wheel features a clean 6 windowed spoke design with a debossed METHOD logo. The lip undercut simulates a true beadlock wheel and has replaceable lip bolts with optional colors available. It boasts a strong load rating of 2,500- 3,640 lbs.
  • Toyo AT3 35” Tires 35x11.50r17LT: Best tires I've ever owned. An aggressive all-terrain tire that offers drivers of CUVs, SUVs, and light trucks exceptional braking, handling, and off-road traction plus an up to 65,000 mile limited tread life warranty.
  • N-fab Steps: These steps are built of a heavy gauge 3-inch rail that sits up close to protect your trucks body. It's the perfect fit with superior strength and protection.
  • Magnaflow Cat-Back: The cat-back system improves airflow, which means the engine doesn't work as hard to eliminate exhaust fumes. The reduced resistance minimizes the load on the engine, which leads to less fuel consumption. That said, the vehicle miles per gallon (MPG) or fuel economy increases in freeways and city roads.
  • S&B Cold Air Intake cold air intakes bring cooler air into your engine and combustion chamber. In doing so, cold air intakes boost engine power and efficiency and this sounds amazing
  • Westin Front Outlaw: 2” diameter tube frame with 1 1 1/2” diameter center tubes and integrated bolt-on LED light mounts for up to two single or one double row 30” LED bar.
  • Westin Pro Mod Skid Plate for added protection.
  • Westin Pro Series Rear Bumper: “High and Tight” best describes the great-looking new Pro-Series Rear Bumpers from Westin. with LED
  • Westing Pro Mod Light Kit Square x4
  • Westin LED Light Bar Mounted in Bumper
  • Westin LED Light Bar Mounted behind Grill
  • Raptor Style Grill LED’s with a custom switch that looks factory in the vehicle and is shown in the instrument cluster. (VERY CLEAN INSTALL)
  • Custom Switch. In the GMC 1500's the knob to turn on your lights had only one button. I purchased a GMC Sierra 2500 knob which had two buttons. I configured one button to turn on the lights in the grill and the other to activate the lightbars. It looks totally factory and also shows up in the cluster.
  • Putco Venture Tec Rack: PUTCO’s Venture TEC Modular Cargo System begins with a sleek bed rack designed to provide endless mounting options. Constructed using high-quality, lightweight 6061 t6 aluminum, this cargo system allows you to bring anything on the go!
  • Putco Venture Tec Rack extra crossbar for supporting weight on tent system.
  • x2 Putco Venture Tec Molle Mounting Plates for Rack: These amazing cargo storage panels are perfect for latching down nearly anything you want to secure in place like Molle bags, trail gear, construction gear, jacks, or anything your heart desires.
  • x4 Putco Venture Tec Tie Down Anchors, which allow extra areas to tie down gear when on the trail.
  • Putco Luminix Off-road LED Rear Light Bar which is hooked to the cargo light switch and allows more light when working on the tailgate or loading at night.
  • x2 Putco Venture Tec Grab Handels: Supporting took to get up on the roof and pull yourself up. A great tool to have
  • Putco Venture Tec Table: Perfect to have and use while camping and cooking. Locks right into the side of the rack.
  • A brand new reverse camera was installed for quality over what was installed in 2017. Clarity is amazing.
  • A second rear camera was installed into the rearview mirror live dash camera unit. I have this mounted under the rear LED light that sits under the tent for another angle. Perfect for looking at the hitch area.
  • Shovel mount and Ax Mount under the tent for quick access.
  • Bed Cargo Storage that swings out.
  • Pedal Commander: Works incredibly well. I will be having this on any vehicle I purchase.
  • All Top Shade Cover installed at the rear of the truck. I put this there so you can sit on the tailgate and have a place to relax in the sun or stay out of the rain.
  • OffGrid Camper Tent. Honestly love this tent. First to set up and first to take down. It's very easy. You can fit x2 adults and x2 kids or x1 adults and x3 kids comfortably. We have had more in there but overall, the mattress is extremely comfy. Has been used maybe 5-6 times and is brand new inside. No issues or damage.
  • This truck has Sierra Wireless however will not be selling the unit. It will be wired ready to go and can use a Sierra Wireless OR you can use a Cradle Point. I have been on the trail and have been the only one to make calls back home. This is the same technology law enforcement uses in vehicles.
  • WeBoost CellPhone with custom whip adapter. Again this, paired with the Sierra Wireless, is amazing.
  • The truck will be wired for Icom Radio or another radio of your choice. I will not be selling mine with the truck. I did make a quick release so you can take the antenna on and off the truck if you want.
  • Short stubby radio antenna upfront
  • Spray in bedliner
  • Rolling Tonneau Cover
  • Rear sliding window
  • Heater and Cooled seats
  • Bluetooth
  • Navigation
  • Sunroof
  • Flawless leather interior
  • Heavy Duty Floormats from Husky
  • Factory HID Headlights (same as Denali)
  • Ram Mount tablet kit. Will only leave the seat post in there, and you will have to get a new stem and mount. A great feature to have that allows you to use OnX on a tablet.
  • Has Center Keypad Counsle safe made by Lockr-Down.
  • It has a rear under-the-seat rifle safe made by Lockr-Down
  • x2 Rotopax Water
  • x2 Rotopax Gas
  • x4 Rotopax Mounts
Price: $32,000
Known Problems
: Mechanically, nothing at all. Truck is perfect. The paint is starting to fade on the roof a bit, and I have a few scratches on the side from fun in the desert. Other than that, this truck kicks ass.
Things I would do to the truck. Add onboard air and mount under the truck and run though the rear bumper. It would look super clean. Connect the parking assist, and that's it.
