[SOLD] Partner Steel Stove, wind screen, extra grill bars, longer hose - $200
jdzl
The Partner Steel Partner Steel's 16" wide stoves are half the weight of the full 4 - burner stoves, and can still be used with a stove stand. 16" stoves are made to fit inside ammo boxes. Burners have individual controls, deliver 10,000 BTUs of heat each. All hoses are equipped with a safety valve. This automatically stops the flow of gas even when someone forgets to turn off the propane tank. This two-burner comes in 12" x 16".
The windscreen is not only great from keeping wind, dust, and leaves out of your food, but it works to keep your pots and pans on the stove.
All stoves are made from high grade aluminum, and hand welded by our expert, professional welders. The grills are stainless steel and the gas manifolds are brass. Other than the burners, the entire stove is designed to remain rust-free and very low maintenance, providing years of service even in the most harsh environments. All stoves come with regulator and hoses. Take this stove on your next camping or river trip.
Used ours on a handful of trips, going a different direction rig-wise and superfluous to requirements. Gas hose is about 8-9ft long, still stows below burners.
Located in Redding, CA.
dhuss
