SOLD (PENDING SHIPMENT) F/S Battery pack (LiFePo4) 40AH/Pelican case (Houston/TX)
superg
I have a portable battery pack available for sale.
It is a Valence 40AH 12.8V (512 watt hours) LiFePo4 battery.
(https://www.valence.com/products/standard-modules/rt-modules/)
Custom built inside a Pelican iM2075 storm case with Anderson plug connector outside of case. Included is a small 150W inverter.
Battery is in almost new condition. Charging voltage is 14.4. Sitting voltage fully charge is ~13.35.
Rated at 40AH and will handle over 42AH. Depth of discharge can go down to almost complete draining of battery unlike standard car batteries that are rated for only 50% of AH specs.
Weight of entire setup is 18lbs. Comparable lead acid setup would be 60+lbs.
Can be charged with most battery chargers set to AGM or any cheap LiFePo4 charger (not included but can be purchased from AMZ etc for $30-40).
Battery has internal BMS.
Reason for selling: I have a couple of these made to charge my portable car fridge (National Luna), but one is good enough to run 3 days.
Prefer pickup in Houston but willing to ship (probably $40-50 in case there's any additional charges for hazmat)
Petersmithinak
