Joselm954
**FINAL REDUCTION BEFORE REMOVAL**
2019 Covered Wagon Cargo Trailer Conversion Custom Camper asking $7000.00 OBO Located in Ft.Lauderdale, FL
2019 Covered Wagon 7x12x6'6" Tandem axle full Screwless exterior .030 skin instead of .024. Silver Frost. Trailer mounted brake controller with wireless remote fob. 1 piece aluminum roof. 2" spray foam in ceiling and 1" in walls. Maxxair Deluxe powered roof vent. Powered HD tv antenna on roof. 0 leaks
400 watts of solar panels on the roof. EPEVER 40a tracer N charge controller with MT50 remote monitor and wifi module ( can only use 1 at a time ). 2x 100ah AGM sealed batteries ( 1 year old ). EPEVER 2000 watt inverter. Solar runs everything except the air conditioning or you can switch it to run on the 30a shore power plug or on 20a with the included 30a - 20a adaptor.Twin mattress hinged with underbed storage. 6000btu window unit ac mounted in a box under the bed that vents out the floor. Hinged table to fold down while not in use. Hinged end table near bed that folds down as well. 120v 4.1 cubic foot refrigerator. 48" led TV on fully articulating wall mount. am/fm radio with dvd player and bluetooth. Sound bar below the tv. Ikea IVAR cabinets up front with custom counter top. Sink is plumbed directly to water inlet and drain goes directly to exterior drain hookup. No onboard water storage to worry about leaking or becoming contaminated. Dual lock locking side entry assist handle that folds over the door and locks for added security. 24" pull out step under the 36" door. 4 BAL leveling jacks. Electric tongue jack rated for 3500 lbs with integrated led lights and memory function. Takes less that 5 minutes to get set up at your campsite when you arrive. Includes toaster oven that has been used 2 times as well. I built it with the intention to use it more, however it has only been used 3 times. There is plenty of storage in the camper for 1 - 2 people for a weeks worth of camping. Also including the grill that I used 1 time on my last camping trip. Everything works 100% and there are ZERO leaks. Trailer weight is 3260 lbs. Has tandem 3500lb axles with brakes on both axles. Also includes 2x full size spares on matching rims mounted to the outside of the V-nose. I have installed keyed wheel nuts on all tires including the spares for added security. Also included is 2 rubber tire chocks, tongue lock and wheel boot style lock. Free delivery within 200 miles, additional charge for deliveries further than 200 miles. Any questions, please feel free to ask. Pictures are located here https://www.dropbox.com/sh/9mfdrj3ypzz8kmi/AAD1XMwrrfc4wOi9onp_gMLSa?dl=0
