SOLD - Self contained Hot Water, Filter, 50 Litre (13.2g) tank, pump/shower, faucet for sale
Byblos
Selling my self-contained hot shower and water filtration system. Its perfect for a nice hot shower when camping with enough pressure to make it worthwile. Powered by a fused box from your cars 12 volt. You have access to fresh drinking water, hot water from your 50 litre water tank or if you chose to extend the hose, you can do so by connecting it to a river or a lake. Provided you understand the elements of nature from using water from a source.
Please note, local pick-up is preferred in Prescott, Arizona. I can ship anywhere in USA, but it will be a challenge. I will wrap it and put the whole thing on a pallet and ship it out. Its doable, you just have to pay for the shipping.
It includes:
  • 50 Litre (13.2) Gallon slanted water tank from Front Runner
  • Tankless Water Heater from Gasland. Outdoors with 1.58 GPM using Propane tank
  • Pelican systems water filter with its own storage box for easy storage.
  • Blue Sea fuse box
  • Flowjet Triplex Diaphram Auto Water System Pump. 12 volts, 2.9 GPM 50 psi.
  • Powerlet plug for refrigerator
  • 12 Volt plug for accessories
  • Customer cabinet to house the fuse box, on/off switch, quick disconnects, water pump, water filter and water faucet.
  • Propane tank connecter
  • All Brass connections to the tank, hoses and clamps.
The system is ready to use. Just have to secure it in your vehicle. You can remove it if you need to. You can also set up a hose to pull water out of a river or a lake straight to the heater and shower using the same setup.
Does not include a propane tank.
I am including a spare water filter too. You can drink from the filter, and use it for coffee, tea, or cooking as well.
The Tankless water heater works with the battery for instant ignition. It gets hot quick and has temperature and flowrate control.
Price I am asking is $2700
The dimensions are
Water Container: W 1000mm (39.4") x H 350mm (13.8") x L tapered 200mm (7.9") to 150mm (5.9")
Custom Box: 40.5 inches wide, 13 inches high, 8.5 inches deep
Byblos
more pics
iStan814
