SOLD SOLD 1997 25' E350 Class C 4x4 Search and Rescue Command Center (AKA Ski Bum Mobile)
pinsx3
Well known vehicle with a long history FOR SALE: $16,000
Details:
Rare Low Mileage, 4x4, RV approximately 40,000 miles
4x4 conversion done by Salem Kroger (now known as Whitefeather) , DOT plaque from the shop on it. It was originally used by the King County Sheriff/Search and Rescue as a communication/logistics vehicle.
Winnebago RV, the box measures 17' floor length, 25' overall.
Triton v10 gas, with 40k miles (original).
Well maintained, county maintenance through 25k miles.
This has been ski camping/mountain bike truck for a number of years now. It has never given us any issues. Always really warm, dependable, and drives well.
Details:
· 4x4 using F350 transfer case, and Dana 60 front axle, 4hi and 4lo, manual hubs.
· One cab over bed, one bed in back, dinette converts to a twin sized as well.
· Passenger seat on a swivel to face living area.
· Nice/clean kitchen with microwave, 3 burner gas stove, sink, and fridge (everything works well) with new knobs.
· 6 gallon propane tank, we get a week easy in cold weather camping. Also has valve to hook up to a standard BBQ tank for extended use or emergencies. Since I have owned it, I had it plumbed for a fire pit or bbq by the side door.
· Two water tanks under the dinette seats roughly 25 gallons each work fine all winter long.
· Hot water is propane and 120v with the generator
· Powerful- 7kw Onan generator, feeds from main gas tank
· 90amp heartline inverter charger.
· flat screen TV with independent inverter.
· 50 gallon gas tank, gives about a 400 miles range.
· 40k BTU propane furnace--keeps it very warm
· Catalytic Heater above dinette (uses no power)
· 5 CF fridge W/ freezer, 120/12v only
· HWH hydraulic levelers on all 4 corners, can lift the tires off the ground for tire changes as well with a new pump motor.
· 2 new batteries in an exterior compartment
· Two 100 Watt Solar panels on the roof.
· 1.5" IPD sway bars front and rear.
· New front brake pads
· New front Wheel bearings 2016
· Most lights are led, led scene lights on the exterior
· Awnings with new hardware on both sides (large), with aluminum protectors.
· Full bath, shower operational
· 40" LED light bar on front bumper recently remounted and strengthened.
· Led tail/brake lights.
· All seams have been sealed with Eternabond tape
· Tires have substantial tread left. Four new Toyo AT II's
· Has only a black tank, sink drains to that as well.
· New ski locking ski storage aft of right rear wheels. Locking with interior light.
· New heated boot storage for toasty ski boots
· New stereo system with reverse camera amp speakers and sub-woofer
· New LED headlights
NOTES RE PROBLEMS FROM PREVIOUS OWNER:
It's a 20 year old truck, it HAD some issues:
· There were water leaks at some time; it has some delamination in places. I re-epoxied the worst areas and it has not seemed to get worse. All the seams were sealed with Eternabond tape to prevent further leaks. STILL NO LEAKS
· Also it leaked around the AC unit prior to us purchasing it, we removed the leaking AC unit and leaking has stopped.
· The shift cable needs adjustment, it goes into gear fine but the indicator is weird, D is where N is etc. SHIFT CABLE FIXED,
· TRANSMISSION REBUILT WITH HEAVY DUTY TORQUE CONVERTER AND OTHER PARTS AND TRANSMISSION FLUID COOLER STILL UNDER WARRANTY
· Generator needs to be started externally only, the fuel pump has been re wired to an external switch as the original wiring failed. Still runs just fine. GENERATOR STARTS AND STOPS INTERNALLY NOW
· Consider obtaining new rear tires, they are re-treads, still very new, but get some tread squirm on the highway. NEW TIRES NO MORE SQUIRMING
https://www.expeditionportal.com/forum/threads/1997-e350-4x4-winniebago-sold.168346/
https://expeditionportal.com/forum/threads/97-e350-winne-4x4-ski-bum-mobile.119477/
