NOW SELLING SEPARATELY w/ Significant PRICE DROP
TRUCK: $27,500 (add leer topper $850)
CAMPER: $7500
It’s time to buy a house so sadly, I’m selling my beautiful 2005 Dodge Ram 3500 (auto trans) with a remodeled 2001 Fleetwood Angler 8ft truck camper. I’ve owned this rig for three years and it is a dream to drive and camp in. This is your chance to own a coveted 4x4 turbo diesel camper set up!
I purchased this rig with the mindset that this would be my forever truck. 5.9 Cummins - enough said. Repairs and modifications were all made with this idea in mind. Lots of very expensive mods, including a full Custom Thuren Fab Suspension 3” lift done about 4000 miles ago. With this kit, the truck with a +18 offset rim will take 37” tires no problem.
I’m sure there is a lot more I’m forgetting, so you’ll just have to come see for yourself. TRUCK HAS NEVER BEEN TUNED. Engine is stock for all you Cummins guys and gals out there. She purs, turbo is solid, tranny shifts smooth.
The camper is a 2001 8ft Fleetwood Angler. Completely remodeled, floors paint. Installed outdoor shower, smart converter (will not overcharge batteries), 100w solar (can go up to 400W with 3 more panels). Sleep 3-4. Upper storage shelves can be converted to a bunch for a small child, I will include the original ladder for the bunk. 12V/110V TV, I have a Suoki solar generator I use to power the TV if I don’t have house power, which I can include. Buddy heater with a dedicated propane line - heat with no power! AC, fridge works on 110V and propane, furnace, water pump and heat all work, although I have not used everything recently. Resealed roof in the fall the past 2 years for preventative reasons. It snows here in CO! No leaks, will sell with 4 tubes of Dicor RV sealant. Once again, there are a lot of other things I’m forgetting so come see!
Cash speaks, clean title.
Dodge Ram 1500 2500 3500 Cummins 5.9 5.9L 6.7 6.7L Diesel Automatic Lifted Lift Lift kit truck diesel truck pickup line x work truck camper truck camper Fleetwood angler 8ft slide in camper remodeled camping overlander
Off-road offroad off-roading 4x4 turbo diesel 4 wheel drive
CAMPER: $7500
- Thuren 2.5 custom King Shocks front rear, 2.75 tune, Thuren front springs Thuren control arms, Thuren Rear long travel leaf springs and shackles.
- BD Track bar, sway bar end-links, and steering box brace.
- Dynatrac rebuildable ball joints
- Currently 35x12.5x17R pro comp A/Ts, over 95% tread remaining and 35 inch spare with matching rim (60,000 mile warranty on tread).
- Pro Comp 6089 rims 17X9 (might be wrong model #)
- New Air Lift Ultimate 5000 air bags for load and camper leveling
- AFE Cold air intake with particle bag cover. I have a 2nd backup filter I will also include. Cleanable filters
- 5” Magnaflow Turbo back exhaust with 5” Magnaflow high flow Cat.
- 150 GPM FASS Fuel filter kit, installed by ATS. Saves your injectors and is step one if you ever want to do any fueling mods. Coolant can be routed through filter block to heat fuel. Electric heat probes can also be used in the FASS to heat fuel.
- Upgrade pressure solenoid and transducer in tranny. Deep ATS Tranny Pan
- All fluids up to date and recently changed
- Newer upgrade 8.3 Mopar steering box, hydro boost, and steering pump. Steering box went 2 years ago and I replaced the entire steering and suspension system, literally.
- Custom front and rear bumpers built in Denver
- Front 24” Pro Comp led light bar and spots lights with rocker panel switch wired near steering wheel (these lights are made by Rigid for pro comp) ~12k lumens
- Line X bed liner, bed rails, fender and rocker panels, and grill
- All new batter cables and grounds
- Black headlight housing swap with HID zenon bulbs
- Trans temp gauge mount in quad cluster above rear view mirror. Will include and EGT gauge I have yet to install. Room for 2-3 more gauges I never got around to installing. Fuel pressure, EGT, and boost would be my recommendations for additional gauges.
- Infinity Audio, custom Pioneer 4200NVX head unit, rear view camera, microphone, delayed ground bypass, Apple Car play, Android, aux and usb. 500W JL TW3 subwoofer with 500W JL amp.
- Leather seats
- Weathertech front mats
- New pads and rotors all the way around
- Been running Amsoil HD 6x diesel oil. I have an Amsoil oil bypass kit that I have yet to install. Filter down to 2 micron. Test port to send to oil sample Amsoil, they tell you when to swap oil. Allows for up to 20K mike oil change intervals.
- I also have a color-matched leer topper for the truck I can include, negotiable.
