SOLD: Unimog U1350LM (U1550L) w. flatbed + demountable camper unit - still to be finished - Belgium
GuyH
When I bought this mog it had only 4350 mi (7000 km) on the clock. The engine was barely broken in!
The plan was to build a travel vehicle that would fit in a sea container and be shipped safely anywhere in the world. The construction was quite a challenge and the result is impressive. The camper unit can be mounted and dismounted by one person using an electric winch without many extra tools and so the Unimog + the camper fit together in a 40 ft. high cube container, as an alternative to RoRo shipping.
An additional advantage is that when you are not traveling for a while, the original cargo bed can easily be remounted on the Unimog and it thus serves as a truck. The camper unit becomes a tiny house...
Now my priorities lie elsewhere and I have decided to put it up for sale.
Unimog U1350LM
The U1350 LM was a special order for the Belgian army and is actually a U1550L whose engine power has been reduced to 136 hp, something that can easily be increased again to 215 hp or more.
Some important improvements over a U1300L are the modern cab with improved sound insulation, higher payload, stronger axles, the heavier UG65 transmission and the turbocharged engine with intercooler.
Technical specs
- Unimog U 1350 LM (437.110 / 437.111 / U1550)
- Year of construction: 1996
- Mileage: 6982 mi (11236 km)
- Type designation: wdb4371111w
- Vehicle weight (without camper unit / cargo bed): 3950 kg (8700 lb)
- Maximum gross vehicle weight / GVWR: 8500 kg (18700 lb) [can be reduced to 7500 kg for C1 driving license]
- Gross train weight / GTW (vehicle + trailer): 24500 kg (54000 lb)
- Engine OM 366 LA turbo intercooler, Diesel Euro 2
- Engine capacity 5958 cm3
- High air intake
- 24 volt system
- Reinforced chassis and axles
- Heavy duty gearbox UG 365 (8 speed)
- Drive can be switched while driving: 2x4, 4x4 and differential lock on both axles
- New type of interior and lighting
- Wheelbase 325 cm (128")
- Tires: Uniroyal 12.5 x R20 - front and rear 90% profile
- NATO hitch: suitable for a trailer of max. 10000 kg (22000 lb)
- The rear bumper can be raised when driving rough terrain
- Cabin has room for 3 people: driver + two-seater sofa
Camper unit
- Inner dimensions: Headroom 200.5 cm, floor (LxW) 324x214 cm, total inside length (from rear wall to front wall) 359 cm, alcove depth 100 cm, total inside length 459 cm
- Weight: 1400 kg (3090 lb)
- Interior: no interior has been fitted
- Windows: PaBST - Air Tec: 2 @ 100x50 cm, 1 @ 30x20 cm, 1 @ 30x70 cm (the latter has not yet been installed). All windows include fine mesh (black) mosquito netting and blinds.
- Door: insulated, with stainless steel three-point locking system. Door opening dimensions (WxH) 57.5x179.5 cm
- Insulation: walls 40mm PIR, floor 20mm HD XPS
- Floor: oak floorboards 10 mm, jointed with bostik marine sealant
Cargo bed
- The original Unimog cargo bed has been modified for the demounting system.
- Tool box (LxWxH 220x60x80 cm)
- Weight: 850 kg (1875 lb)
Vehicle dimensions
- Truck with cargo bed mounted: LxWxH = 555x230x254 cm (218.5x90.5x100")
- Truck with camper unit mounted: LxWxH = 600x230x335 cm (236x90.5x132")
Accessories
- Original Unimog on-board tools
- Tools belonging to the demounting system
- Bed lift (Project2000 unit )
- 2 x household battery Brega Calcium-Calcium 12v, 100 Ah + Cyrix CT 230 Amp
- 2 x wheel chock
- Fire extinguisher
- Spare wheel: Uniroyal 12.5 x R20 - 100% profile
- Tow bar
- Air hose + tire inflation pump/pressure gauge
- 12 tons hydraulic jack
- pioneer shovel
- 2 x jerry can 20 liters + holder
- 4 x snow chain, Mercedes Benz
Price (Unimog + Camper unit + Cargo bed + Accessories)
- 68,000 euros.
For more photos and videos have a look at: https://www.globaltravelconcept.com
travelall74
