This is a used Zodi Shower w/ no burner. It will come with the case and an extra long hose that I extended with the stock hose/spray.
I used this with no burner so there is soot on the bottom. It should come off with some soap and steel wool. The unit shows signs of use, but no dents or anything crazy.
I'm asking $80. Item is located in Redondo Beach.
The dark lines on the upper part are reflections. You can see the soot on the lower part.
