Merakivanman
This 2008 E-450 shuttle bus overlanding conversion was built from the ground up over the last year. This has the space and storage to take extended overlanding trips to the desert, the ski slopes and everywhere in between. This has all of the practicality to enjoy all of the experiences of van life, with more of conveniences of home and way more space. When you want the comforts of a full size RV but still want to be able to get off-road for extended periods of time this is the ideal way to travel. This has over 10 inches of ground clearance and 4wd locking hubs with off-road all terrain tires you can just about go anywhere you want.
It has front and a rear heavy duty A/C, 2 furnaces (one propane and one rear auxillary heater from the coolant lines of the engine.
4wd Hi/Lo Dana lockers with all OEM Ford axles with 6 inch lift kit and 6 inch bigger tires than stock. 8 inches of additional ground clearance.
Asking 40,000.00
Please message to get in touch!
Summary:
This has full overlanding capability for extended periods with a large solar and battery system, heating and a/c and custom tuned suspension, the capabilities are endless and a way more spacious interior than a traditional Sprinter, Transit and half the cost.
The Bus:
Reach out if you have additional questions. joekelleyphotography@gmail.com
Thank you - Joe
Willing to deliver.
Asking 40,000.00
Summary:
The Bus:
- 2008 Fully customized Class B motorhome conversion
- 25 foot length
- 6.8 liter v10. (just went through by a mechanic and had the oil changed..ready to take a cross country trip tomorrow.)
- 118k miles
- Brand new custom 4wd conversion and lift based off of Quigley conversions with better offroad capability.
- Fuel economy is around 9mpg at 70mph
- Noise deadening material used throughout
- Closed cell foam and natural batt Insulation (comfortable in high temps and below freezing conditions with supplemental heating and a/c.
- Coilover suspension with custom tuned front and rear progressive rate Bilstein shocks
- Dynatrac/spicer Dana 60 Front/Rear axle.
- NV 271 High/low Transfer Case
- On the fly high/low 4wd shifting
- Detroit Locker Dana 70U with 35 Spline Axle Shaft upgrade rear end.
- 200 miles on 4wd system (Rides so smooth compared to leaf sprung front end conversions)
- 33 inch Wildpeak ATP
- 17 inch custom Quigley wheels
- Custom Front and rear Trac Bars
- Heavy duty sway bar with custom links
- Waterproof vinyl flooring
- Custom memory foam couch cushions and pillows.
- 65 gallon onboard freshwater tank with additional 10 gallon grey water tank
- 95 liter Dometic DC Fridge/Freezer with bluetooth
- On demand 4.5 gallon ceramic coated electric water heater for shower.
- Full Sized bed
- Full sized Shower
- Cassette toilet
- 60lb undermount Propane tank.
- 16k BTU electronic ignition suburban propane powered RV furnace with wall mounted thermostat. (Sips fuel and is super quiet.)
- Auxiliary rear furnace
- Rear Mounted A/C - pumps ice cold air
- Electronic Ignition 2 burner propane Stovetop
- Full- Sized Stainless steel farmhouse style Kitchen Sink
- Custom Birch butcherblock countertop
- Custom bench seating with storage underneath
- Rear storage by bed
- Upper shelf
- 3 drawer cabinets with 2 upper 12 inch cabinets
- One way privacy film on windows
- Massive Storage area under the bed, under couch, kitchen, upper shelf, rear storage
- Meraki Expedition vehicles Solar package
- 410 Watts of Solar
- 40AMP bluetooth Renogy Charge Controller - bluetooth app tracking for voltage, watts and tracks day to day solar statistics
- Maxair - Low profile Remote high volume Roof Fan. Automatic rain sensing and allows fan to be run with it lowered at the same time
- Renogy 2000 Watt inverter with remote switch
- 600 amp hour Renogy AGM battery bank - Brand New
- 3 zones of dimmable led lights for upper and lower lights.
- Led touch sensitive reading lights on bed
- Dual USB plug-in in front and in kitchen.
- Low profile 120v pop up 3 socket electrical on countertop
- Low profile 120v slide socket in front of couch
- All electrical accessible in rear storage area
Thank you - Joe
Willing to deliver.
