Something for your First Aid Kits
Digger Dave
Found this on the web this morning after a coworker told me about it. They carry / use this stuff all the time in Iraq and Afghanistan. Given how remote we can be when on the trail, it looks like a must have for saving lives. This web site is one of many that you could probably but it from . . .
http://www.bestglide.com/celox.htm
Dave Bennett
Adventurist
Quick Clot Type Products
This stuff is not to be used unless for a life threatening emergency!
This is virtually the same as Quick Clot that we use in Iraq and elsewhere.
This stuff requires training to use properly. Once used, it requires SURGICAL removal!
It is to be used ONLY to control External Hemorrhage.
So, in the interest of safe overland travel and education, here is your period if instruction on the proper use of Quick Clot:
External Hemorrhage- Loss of blood from wounds that damage the large vessels of the extremities are a common source of massive external hemorrhage in combat. Some examples include, bleeding from open fractures and large, deep, soft tissue wounds.
(1) Signs and Symptoms – obvious bleeding from a wound
(a) Types of Hemorrhage - Hemorrhage is defined as blood escaping from arteries, veins or capillaries.
1. Arterial - If an artery near the surface is cut, BRIGHT RED BLOOD will gush out in spurts that are synchronized with the heartbeat.
2. Venous – Blood from the veins is DARK RED. Venous bleeding is characterized by a steady, even flow.
3. Capillary - Capillary blood is usually BRICK RED in color. If capillaries bleed, the blood oozes out slowly.
(2) Causes of External Hemorrhage
(a) Penetrating wounds
1. Gunshot
2. Stab wounds
3. Shrapnel wounds
(b) De-gloving Wounds
4. Vehicle accidents
(c) Amputation Wounds
HEMOSTATIC AGENTS
a. Purpose - When applied to a wound, it will cause the wound to develop a clot that will stop the flow of blood and will remain within the wound until removed by medical personnel. The hemostatic agent is approved by the Food and Drug Administration (FDA). Each Marine is issued one packet of QuikClot in their Individual First Aid Kit.
b. Indications
(1) Moderate to severe venous or arterial bleeding
c. QuikClot: works through rapid adsorption of liquid in blood
(1) This adsorption is purely physical, not chemical in nature. (Adsorption: physical adhesion of molecules to another substance, not a chemical reaction)
(2) In the presence of normal blood, this adsorption causes only a slight body temperature increase to approximately 109-114 degrees F. If blood is extremely diluted, exothermic reaction can be more extreme.
(3) In the presence of liquids like WATER, more extreme heat can be generated by this adsorption. This reaction lasts approximately 4-5 seconds and then ENDS. Once granules have adsorbed all of the liquid possible, they go INERT.
(4) Exothermia (production of heat) is controlled by adjusting the balance between volume of water and volume of product.
(5) Flooding the granules with water can instantly arrest the exothermic reaction and adsorption.
(6) Application Procedures
(a) Apply direct, firm pressure to wound using sterile gauze dressing or best available substitute.
(b) If bleeding is stopped or nearly stopped after 1 minute of pressure, wrap and tie bandage to maintain pressure on wound and seek medical care.
(c) If moderate to severe bleeding continues after 90 seconds, hold QuikClot away from face and tear open at tabs.
(d) Remove previously applied bandages, making certain to wipe away as much excess blood and liquid as possible.
(e) Pour (DO NOT DUMP) QuikClot in a back-and-forth motion onto the source of bleeding. QuikClot changes from its dry light beige color to a dark color as it adsorbs moisture and begins to clot.
(f) Stop pouring promptly when you see a dry layer of QuikClot on wound indicating that there is no more blood to adsorb.
(g) Immediately bandage wound and apply firm direct pressure.
(h) Transport patient as soon as possible to a medical facility.
(i) Be certain QuikClot package accompanies patient so physician or medical staff can follow directions to remove QuikClot properly.
(7) Precautions
(a) Sucking chest wounds- Use particular care around sucking chest wounds to prevent QuikClot from being aspirated into lungs.
(b) Spurting blood- The caregiver should be aware that continuously spurting blood from a small diameter puncture wound could create a high-pressure exit path. The source of such bleeding may be too far away from the entry point for QuikClot to be effective.
1. Slow the bleed with a tourniquet for extremity hemorrhage or pressure points for non-extremity hemorrhage, and then apply the QuikClot in conjunction with a pressure dressing. SLOWLY release the tourniquet or pressure point. Reassess effectiveness.
(c) Head and scalp wounds produce profuse volumes of blood that can cause discomfort from the exothermic reaction during application of QuikClot.
(d) Do not ingest or inhale QuikClot!
1. If ingested, drink several glasses of water and seek medical help
2. Keep away from the face when opening or pouring
3. If inhaled, move to open air or a well-ventilated space
(e) Do not use bare hands to apply pressure immediately following application of QuikClot, it will get very hot!
(f) If adsorbing granules cause heat discomfort to skin, promptly brush away and/or flood with water.
(g) Sterility not guaranteed if package is damaged or opened. Safely discard damaged open packages.
(h) Keep away from children!!!
NOTE: If you cannot see where the hemorrhage is coming from, DO NOT use QuikClot. It must be poured on the hemorrhaging vessel to be effective.
REFERENCE: Fleet Marine Force Corpsman Field Manual, 2006. United States Navy
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
Excellent info, Dave.
You took the words right out of my mouth...sort of... :rolleyes:
Digger Dave
I appreciate your comments, but now I have conflicting information. According to the CELOX website "no training required".
I'm not disputing your training or anything (and thank you for your service!) I just need to know. :confused:
taco007
In a recent study published in the Academic Emergency Medicine Journal Celox was found to be slightly better than Quickclot and HemCon. Additionally, it does not generate heat like Quickclot, is effective in the absence of clotting factors, and in patients who are hypothermic (unlike Quickclot). Afterward, it needs to be irrigated out of the wound like quickclot (usually in surgery since the wound it tempararily corrected needs to be repaired and cleaned. This would most likely be the case even if a hemostatic agent was not used on the wound).
Bottom line...get it, get some training on it, use it on indicated wounds only (not the small, easily controlled wounds).
Also carry a rapidly deployable, function-built tourniquet for massive extremity bleeding and put it on sooner rather than later (CAT Tourniquet, SOF-T Tourniquet, etc). Don't buy into the old teaching of "tourniquets as a last resort"...if you are bleeding badly from a extremity wound you don't have time and resources to try all the basic first aid treatments before putting a tourniquet on.
Dave Bennett
Adventurist
flyingwil said:
Great info there Dave!
Thanks Wil!
X2 on the CAT tourniquet, every real back country first aid kit should have two of these!
A CAT tourniquet, applied quickly, is a huge aid in stemming blood loss from an extremity and requires very little first aid training - just put it on above the wound and tighten it up!
Dave Bennett
Adventurist
Yes, the site may proclaim "no training required", they are in business and want to sell the product first and foremost.
I recommend that every back country traveller or "Overlander" take at LEAST a Basic First Aid class (to include CPR) or better yet, a Wilderness First Responder course.
If you have already been to a course and it has been a few years it is always good to update your knowledge by attending a refresher, technology and the science of medicine is ever changing so it's always good to know the "latest and greatest".
You can spend lots of money on the best first aid bag and all the high speed widgets but in a real emergency it will be your wits and your calm, cool demeanor that save the day. Training is worth every penny IMO.
tdesanto
I added Celox to my kit last year. I found this company easy to deal with and had great customer service.
They also had the SAM splints too and lots of other important items.
I think caution is warranted when using a clotting agent as medical removal of the material is necessary. But, if the situation is that bad, I think it's good to have at least one pack of this stuff.
Now, as to using a tourniquet, I had always understood these to be more of a catch 22 situation. You could lose a lot of blood if you don't use one; you could easily lose a limb if you do. I currently don't carry one, because I'm not sure of when I should use it.
Dave Bennett
Adventurist
If you have a life threatening bleed (hemorrhage) on an extremity, do not hesitate to use a tourniquet! The average man has only 5 to 6 liters of blood, so blood loss can quickly turn fatal...
If the bleed is arterial (as evidenced by copious amounts of spurting, bright red oxygenated blood) and on an extremity the quick, proper placement of a tourniquet is critical. Once the bleeding has been stopped and the scene is under control, transport them to a hospital immediately.
In my experience, a guy with a tourniquet on a limb will do just fine (he will not lose the limb) IF you get him to definitive care within 6-8 hours.
If it is left on longer he will likely lose the limb but he will LIVE :)
Don't let fancy new products like Celox or Quickclot give you a false sense of security - they are not intended to stop arterial bleeds on extremities, the pressure will easily blow out any clot formed.
A good old fashioned tourniquet is still the best means of stopping ANY life threatening bleed on an extremity, and you should have at least one in your medical kit!
roberto
X2 on Celox, and any type of combat tourniquet, I keep a good first aid kit with all this stuff with me at all times along with Normal Saline and admin kits in the back of the cruiser. LIFE OVER LIMB! After u stop the bleeding with a tourniquet you can apply a pressure dressing to the wound and then loosen the tourniquet and see if the pressure dressing holds/ stops the major bleeding.
Rob
quigleyth
